I have problem understanding how the gatedriver below works :drowning:
Do I set ref to the voltage I want to retain on the output ?
Input is only for turn on the gatedriver ?
http://www.fairchildsemi.com/ds/FA%2FFAN3111C.pdf
ref is for setting the logic levels for the input, i.e. if you intend to drive 'in' from a 3.3 volt mcu you would connect ref to 3.3V. Anything over ~50% of vref will be seen as high, anything below ~30% of vref as low
Vdd drives the output
-L
langwadt: Ok I have get it totally wrongthank you for the input,
how do I know what the fan3111 sends out then when the output is set to high ? :idea:
