588,390 active members*
5,488 visitors online*
Results 1 to 11 of 11
    Jan 2007
    29
    CNC BAR FEEDER
    MY CNC BAR FEEDER 6 TO 12 FOOT BARS HIGH RPM CHECK OUT VIDEO
    PATENT PENDING
    [ame="http://www.youtube.com/watch?v=jlG-42Ge3E4"]YouTube - CNC BAR FEEDER[/ame]
    May 2008
    85
    Very useful and an interesting design, but unless the bar is being fed in by the unit and not pulled in by the tooling, (not apparent either way from the video) it's not a bar feeder.
    Jul 2005
    12177
    I hope you plan on putting some guards around it.
    What is your idea of high rpm?
    Jan 2007
    29
    RPM 3500
    It has been run at 3500 rpm and it should do 6000 rpm with roller every 4 inches it does not vibrate, I have run this one about 1000 hours and no wear
    so we plan on making these for six foot bars
    Thanks you for checking the Bar Feeder
    Alan Hiiesalu
    Jan 2007
    29
    Adding pusher to bar feeder
    Yes to be a bar feeder it needs a pusher and that can be added with a end of bar detector and feed hold or reset circut to stop the CNC at the end of
    the stock
    Jul 2005
    12177
    I would not like to be near it with a 12' bar running at 6000 rpm and the BARFEEDER supported by a single bracket to the machine.
    How do you accommodate different size bars?
    Apr 2005
    3634
    That's what I was thinking. The machines I've ran all have feed tubes, for the stock material.
    Do you have a complete setup for each bar diam. ?
    Free DXF - vectorink.com
    Jan 2007
    29
    Adjustment
    The rollers adjust from 1.375 down .375 by rotating a collar and locking in place or there is Type 2 a driven tube that uses liners to center hex or square stock. and for now I am working on 6 foot units.
    The amount of power used to rotate the unit is very small barly notice on
    spindel load .
    And a 12 foot unit will have a lot of support and guards pro built by our shop
    This unit is to demo what the patent office wants to see.
    And Thanks for checking this out
    Alan Hiiesalu
    Thoroughbred Precision
    Jul 2005
    12177
    Quote Originally Posted by hiiesalu View Post
    Yes to be a bar feeder it needs a pusher and that can be added...
    A 12' bar sticks out about 9' from the end of the machine and a 12' pusher is needed to push this bar full length; therefore you need somewhere around 24' past the end of the machine to fit all this in. You cannot bring the pusher in until the machine has stopped and cannot restart the machine until it has been retracted so pushing is going to be very slow.
    I will agree that this is an innovative approach but having had experience with barfeeders that could handle 12' bars on manual machines and smaller feeders on CNC machines that can advance the bar with the spindle running I am dubious about the practicality and potential market size.
    May 2007
    100
    Looks interesting. Do you have any more pictures or videos? Can you show how the bar was advanced in your video ?
    Very Nice !
    Jan 2007
    29
    Reply
    JHCOPPERS
    Thanks for the remarks, We are working on drawings and a prototype of a manufactured model.
    I have had a lot of people who are interested in one for there CNC
  1. FEDEK BAR FEEDER
    By CHANDRU in forum CNC Swiss Screw Machines
    Last Post: 10-25-2022, 04:43 AM
  2. MOVABLE BAR FEEDER
    By JMECKES in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2012, 02:00 PM
  3. Bar feeder question
    By cutting edge in forum Haas Lathes
    Last Post: 09-28-2008, 03:52 AM
  4. MTA 541 Bar feeder
    By DocHod in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2007, 04:03 AM
