Hi all I need help with identifying wires on 34H2160-62-8A nema 34 12Nm 8 wires (white, black, red, yellow, orange, green, brown, blue) from ms motor world.
To find the phase pairs use an ohm meter and ring continuity. To find phase polarity, tape a tooth pick or some long stiff piece and tape it to the shaft to "magnify" the rotation. The take a D cell and connect a phase noting which way the step happens,clockwise or counterclockwise. Keep track so that you can determine whch lead connected to the + of the D cell makes it rotate the same direction. At the end you should be able to mark eah color pair belong to a phase, and which of the colors of the pair make it travel a certain direction. Thats enough to get you started so you can hook up a driver and determine the final pairing.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Nice ruler! :banana:
Take a look at this one, it could be match. You must translate colors from German.
ok I just got this from my supplier but now the problem is my Japanese isn't good, can someone translate it for me? see my attachment.
15mgtar,
I believe this is the wiring for your motor, you can double check it with a ohm meter as Phil has suggested.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
