603,780 active members*
4,044 visitors online*
IndustryArena Forum > CAM Software > Vectric > its the little things that bite you on the a$$
    Feb 2006
    210
    devoted vcarve user here. I cut mainly machinable wax for foundry patterns and was having trouble getting a good cut. Letters wer muddy and misshaped etc. I tried everything- many hours spent adjusting the backlash out of my homenmade machine( worthwhile in itself). Nothing helped.
    Last night I am teaching my daughter to use vcarve to do some medallians she wants. As I am explaining the tool database and bring up the 'v-bit 60 deg .25' that I use 90 percent of the time, it suddenly jumped out at me--- the bit was set to 90 degrees!!!!! OMG! Talk about feeling silly. I had changed laptops to get a very light one ( big time busted leg- long recovery) ( an Eee PC- reccomended) I somehow changed the setting.
    Got a new medallion to do so recompute with correct settings and just cut a test--beautiful!
    I guess what I'm saying is CHECK YOUR ASSUMPTIONS when you have a problem. Its the little one that will screw you.
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Feb 2007
    1084
    Teaching is the best way to learn! I am a firm believer in that.
    MC
    Aug 2005
    597
    Hi Dave,
    I'm guessing you are running an older version of VCarve Pro because we had
    a release that installed a 'faulty' Tool Database. The 60 degree V-Bit was set to have an included angle of 90 degrees - as you have found out - Very sorry about that
    Glad to hear you are now getting good results
    Tony
  1. Replies: 42
    Last Post: 10-05-2011, 12:32 PM
  2. Mitee Bite clamps
    By ajl6549 in forum MetalWork Discussion
    Last Post: 05-07-2009, 04:27 PM
  3. IH mill t-slots and mitee-bite t-slot clamps
    By altaic in forum Charter Oak Automation Support Forum
    Last Post: 12-24-2008, 07:56 AM
  4. Mitee-bite xpansion clamps
    By pp-TG in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-18-2008, 12:05 AM
  5. Mitee-Bite
    By loves80z in forum Linear and Rotary Motion
    Last Post: 11-03-2005, 04:30 PM
