603,936 active members*
3,370 visitors online*
Hybrid View
sonicwonder2000 Steel router on wooden table? 05-29-2009, 10:53 PM
BobF A well built wooden table... 05-29-2009, 11:24 PM
    Sep 2007
    146
    I'm in the midst of building a belt-driven cnc based loosely on the Solsylva design. With the price of steel being what it is, I'm considering making the gantry, cnc body, and rails out of metal and placing the whole thing atop a wooden table. In the pic below, I'm considering making the blue box out of wood.
    Will the wooden table cause a degredation in the performance (accuracy & repeatability) of the router? Would I be better off spending the extra $$ and building a steel table to place the router on. The white "guts" will weigh about 175Lbs so will still be moveable if necessary. Building the entire thing of steel will raise the weight to well over 500 Lbs - i.e. not transportable.
    Thanks for your input.
    Sep 2007
    740
    A well built wooden table should cause no degradation. Make it flat and level you should be fine. When I want mobility, I install casters and leveling jacks. I install the jacks so that they can lift the table off the wheels slightly. This prevents the table from moving as well as allowing you to level it on most any floor. Just raise the jacks to lower back onto the casters and move it where you need.
  1. Reference Table for Steel Material
    By nearbeer in forum Mechanical Calculations/Engineering Design
    Last Post: 10-09-2008, 12:08 AM
  2. Buying 1-axis table, steel duty
    By DrStein99 in forum Linear and Rotary Motion
    Last Post: 08-20-2007, 02:13 PM
  3. my cnc wooden table.
    By steve knight in forum CNC Wood Router Project Log
    Last Post: 04-10-2007, 04:48 AM
  4. 120x240cm(work area) Router Table - steel/aluminium
    By Goose80 in forum DIY CNC Router Table Machines
    Last Post: 12-13-2006, 10:43 PM
  5. Steel for compound table?
    By plasticad in forum Linear and Rotary Motion
    Last Post: 11-04-2006, 08:07 PM
