586,068 active members*
4,238 visitors online*
    Mar 2009
    53
    C-axis resolver
    Hello,
    I own an Ikegai FT20Z lathe with fanuc 10 control. When I go to milling mode (M18) and try to do anything with the C-axis, the control gives me an SV007 error (exeed, moving). When I look in the diagnostics, the error on the C-axis is -128 constantly. Also the C-axis values are not registered when I turn the head manually. I think it is the resolver, the preamplifier or the RES/IND board (A16B-1210-0460). Does anyone know if any of these things tend to break down easilly? The resolver disks have had some oil coming from the hydraulics.
    Does anyone have parameters for the FT20Z. A list with descriptions of the fanuc 10T paramters would be equally nice.
    Kind greetings,
    Pascal.
    Mar 2009
    53
    Hi again,
    I have found the solution to this myself. On de IND/RES measurement board there is a potmeter that sets the gain of some amplifier. With this I got the measurement stable. Do not hesitate to contact me for details.
    greetings.
  1. Y axis resolver/over temp faults
    By smittys800 in forum Fadal
    Last Post: 06-11-2009, 05:57 AM
  2. resolver removal
    By will_lewis in forum Servo Motors / Drives
    Last Post: 01-06-2008, 02:32 AM
  3. Encoder vs resolver
    By zoeper in forum Servo Motors / Drives
    Last Post: 04-25-2006, 06:42 PM
  4. Encoder or Resolver?
    By bcromwell in forum Stepper Motors / Drives
    Last Post: 07-23-2005, 03:26 AM
  5. Resolver question?
    By 69owb in forum Servo Motors / Drives
    Last Post: 07-20-2005, 02:42 AM
