586,471 active members*
3,870 visitors online*
Results 1 to 6 of 6
    Jun 2005
    176
    Want to update Multicam router
    Hi All. Well I have been a member here for around four years and here's my first ever post! I've always dreamed of building a 3 axis machine but time has not permitted. Recently I needed to use a local business with a CNC router and subsequently I have become friends with the owner. He has a Multicam 3 axis machine and bought the business as a going concern from the previous owner. As it stands, he's running a DOS based software package and has restricted his work to doing 2D profiles. When I asked him if he could do some 3D work for me he responded that he didn't have a good enough understanding of the software to attempt it. I'm on a mission now to find out if there is an economical route to upgrade his machine via a new controller and software that will give him 3D capabilities. I'd appreciate any advice the members could offer. Here's some pictures of the machine and controller.
    The motors that run the gantry are steppers but they were under covers and the machine was working so I couldn't get a snap of them. Thanks in advance for any advice.
    Nov 2007
    2466
    i am gonna venture to say the motors are nema 34 base's and are 1.8 degree steppers, if you can get the specs off the end of the motors (amps) and see if he has any documentation on the machine, can you see a name or model number for the drives, power supply etc. i would try a free file from vector art 3d (he gives you the software free) and try a sample file first. chances are the machine is ok! doss controllers were great!! it is just a controller and if the machine will handle not loosing steps you might have something there. i converted machine from dos to wincnc and later found it was my 1/2 step anaheim drives that were my limitation, i have since completed a complete retrofit to wincnc, keling motors, geckos, and 72v power supply,
    2000-2500& actual cost to have someone do it is 4000+ now the machine is a 3d speed machine.
    try a file first,
    www.vectorart3d.com
    download his 3d machinist program (free) and his sample file (free) then run a small one at default size after that expand it to say 12" and see if there is a difference
    what is the file extension that goes to the machine .tap .nc ? and what is the software he is using to create the file
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Jun 2005
    176
    Thanks Jim :)
    Thanks for the response Jim.
    I'll check into the file extension and have a look at the software you've suggested. I think the main difficulty with this situation is the owners reluctance to alter a machine that is currently working and making money for him.
    The best outcome I can see is that new software can be brought in to work with the existing electronics. If i can, I'll get the specs off the stepper motors.
    I know he's got two pallets of MDF to cut this week so i may have to hang back until this job has gone through.
    Nov 2007
    2466
    my bet is the machine will do it as is!!
    jim
    Nov 2007
    2466
    you can also go to vectrics site www.vectric.com and download thier demos for all of thier software, there are demo files you can run as well
    jim
    Jul 2006
    40
    I know that some of the Australian Multicam brand (different company here in the US) machines were made by AXYZ in Canada:
    http://www.axyz.com/
    AXYZ has great support and can probably answer your questions if they, indeed, manufactured this router.
    Art Pentz (AXYZ machine owner).
  1. Newbie needs help with DNC hookup to Multicam router
    By newlife in forum Commercial CNC Wood Routers
    Last Post: 06-02-2009, 10:07 PM
  2. Australian multicam cnc router
    By BGH in forum Australia, New Zealand Club House
    Last Post: 07-16-2008, 11:58 AM
  3. Bobcad on new Multicam router
    By StephenSebastia in forum BobCad-Cam
    Last Post: 05-18-2008, 12:47 AM
  4. Cutting Stainless steel on a CNC Router (MultiCam)
    By routski in forum MetalWork Discussion
    Last Post: 03-27-2008, 06:00 AM
  5. Update for my router.
    By MonoNeuron in forum DIY CNC Router Table Machines
    Last Post: 02-02-2005, 01:09 PM
