Thinking of giving the David laser scanner a try.
Any way to get a tool path off of a stl file?
Is a sentance fragment?
MeshCAM, Vectric's Cut3D, I think CamBam, and pretty much every other higher priced CAM package.
You can also do this at zero cost using FreeMill... you will need to edit the post-processor to use the code with mach control software.. or try one of the visualMill based post-processors available at MecSoft.
The VisualMill Mach post-processors are reported to function OK with FreeMill.
I've attached an image showing an .STL I test cut using Mach2 and FreeMill gcode.
Hope this Helps
Danny (aka Yohudi)
What one man can do another man can do..
BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
STLWork -- not free but has a demo. About $125 as I recall. Seems like you have a range of choices.
BTW -- Let us hear how you like DAVID. Good thinking - ahead. Find a processor for the output --before generating the output!
Cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Vectric Cut 3D works great for this, and it's pretty cheap too! You can download a free trial version. It'll let you post the file, but it adds a watermark until you get a license.
Brad Thomas
My Stuff: Vortech Router, Mach3, Vectric Software
