603,834 active members*
2,721 visitors online*
    Jun 2009
    Press bed skew
    Is it OK to shim a press bed that is bowed about .015"
    I get conflicting answers.
    I cannot afford to send the entire press out to be re-machined.
    Feb 2005
    117
    Press bed skewed
    It depends on what you are cutting with and the exoected life expendancy of the tool.
    What is the distance of the .015 bow?
    Are you cutting with steel rule?
    If you are cutting with steel rule what are you using as a consumable surface?
    Are you using a die set?
    If so is it a two post or four post die set?
    Need a little more information to help you out.
    Been there and done it,
    JohnD
    Jun 2009
    Press bed skewed
    The bed is about 40" accross and is bowed the entire distance with the center being down .015"
    I checked it useing a precision starrett level and feeler gauges.
    We use die sets but cut thin materials, with more than one layer at a time.
    (Usually .012" aluminized, .001" aluminum foil, and .015" 409 stainless steel)
    Die sets are four post
    Thanks for the reply, hope the information helps
  1. die for a press
    By Eagle23 in forum Diemaking / Diecutting
    Last Post: 06-21-2009, 07:55 PM
  2. NEED MOLD PRESS HELP
    By BAD DOG in forum Moldmaking
    Last Post: 02-09-2009, 03:48 PM
  3. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
  4. PRESS Size?
    By ZipSnipe in forum Diemaking / Diecutting
    Last Post: 12-08-2006, 03:52 AM
  5. Q: Press Fit
    By Deviant in forum MetalWork Discussion
    Last Post: 09-11-2006, 07:20 AM
