586,058 active members*
4,243 visitors online*
    Mar 2006
    9
    What are 'post-processors'?
    I am just getting into CNC and am reading up on CAM packages. One claims to have "100s of post-processors". What are these and what are they for? The blurb obviously assumes I should know!
    Thanks.
    Feb 2008
    586
    Every machine tool has their proprietary programming quirks and abilities. You CAM package doesn't know which machine you are going to use, or how you like to see the program compiled. It will take your inputs, and, using the proper post, output a program that suits you and the application. If then you have a different machine, with different quirks, then you'd re-post for that machine.
    Mar 2006
    9
    Ah, thanks beege. I am using Mach3 so I guess that I ned to buy a CAM package with an M3 post-processor.
    Cheers.
    Feb 2009
    64
    Lazy Cam
    Mach 3 comes with a free CAM program called lazy cam that is useful for small projects. I have had no problems loading posted code made for other machines into mach3 also. I have also been able to run code made for mach3 on a haas machine as well with only minor adjustments.
    Nov 2008
    31
    DOING A LITTLE BLOG ON TURBO CAD TAKE A http://wwwstugod.blogspot.com/ FROM stugod
  1. post processors?
    By john_t_h in forum Syil Products
    Last Post: 11-26-2018, 05:01 AM
  2. how do I set my post processors
    By Alan0166 in forum BobCad-Cam
    Last Post: 06-04-2015, 08:15 AM
  3. post processors
    By littlerob in forum Okuma
    Last Post: 12-06-2008, 06:26 PM
  4. V20 post processors
    By doug6949 in forum BobCad-Cam
    Last Post: 02-22-2005, 02:49 PM
  5. post processors
    By Turn Man in forum Uncategorised CAM Discussion
    Last Post: 05-30-2004, 07:13 PM
