586,094 active members*
4,034 visitors online*
    May 2008
    10
    turbocnc X Diameter mode
    i'm wondering is there a X diameter mode in Turbocnc, cause i,m trying to run a Gcode from MasterCam software but it say the radius not posible. any idea !
    Mar 2004
    1806
    From the manual, it depends on "Machine Type" In the configuration menu:
    Machine: Allows be specification of the general type of CNC machine being controlled. This setting affects how TurboCNC interprets RS-274 D Code as follows:
    • Radius Lathe: The X axis (cross feed) is used as specified when processing a move. This default plane is set to G18 at startup.
    • Diameter lathe: The X axis (cross feed) is halved internally before processing a move. Earlier versions of TurboCNC had a cryptic way of setting this via an AxisPreScale parameter in the ini file. This default plane is set to G18 at startup.
    Under the General config. menu, there is a drop down menu and you select the appropriate type. Mine is showing Mill/Drill right now, but you can change that. Don't forget to save the config changes and then reset the ports!
    Good luck
    Art
    AKA Country Bubba (Older Than Dirt)
    May 2008
    10
    thank , Bubba
    Hi , Bubba thank for your info, now i'm running my turbocnc in Diameter Mode:banana:
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. spline mode nurbs mode
    By cooltool in forum CamSoft Products
    Last Post: 03-10-2009, 08:03 AM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  4. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  5. VisualTurn diameter v/s radius mode
    By whiteriver in forum Visual Mill
    Last Post: 05-10-2006, 05:56 PM
