586,111 active members*
3,744 visitors online*
    Compression Cutters
    i use cruing (might not be known in the states) compression cutters, there great brand new but when i get them back from sharpening or re tipping (from the same company) they fall to bits usually within the same day.
    was wondering if anyone has the same problem with resharpened/retipped compression cutters
    We've gotten ours sharpened from two different places, and both cut like new, although the life is a bit shorter after sharpening.
    cheers, think we'll try another company. We had 2 cutters go in the same sheet of ply both of which had been retipped. I think its a problem with whatever adhesive they use to stick the new blades on
    Oh. I use solid carbide spirals. Big difference.
  1. Tension & Compression tapping
    By cnc steve in forum MetalWork Discussion
    Last Post: 04-04-2009, 11:10 AM
  2. LETTERING HARDWOOD CUTTERS? AND PLYWOOD CUTTERS
    By andycorleone in forum WoodWorking Topics
    Last Post: 12-12-2008, 07:36 PM
  3. Nikken Tension Compression Tap Holder
    By rbleth51 in forum CNC Tooling
    Last Post: 07-15-2008, 02:49 PM
  4. Hydraulic compression endmill holders
    By Geof in forum CNC Tooling
    Last Post: 12-09-2007, 03:09 AM
  5. Tension/compression tap holders
    By Caprirs in forum MetalWork Discussion
    Last Post: 04-05-2007, 01:59 PM
