586,369 active members*
3,230 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Newall C80 readout on Hardinge HC Chucker Lathe
    Here are a few pictures of the installation of a Newall C80 display with Spherosyn Scale and associated reader head on my Hardinge HC Chucker.
    I only need the A/C adpater yet to complete the project. I ordered one today and hopefully it will be here by the end of the week.
    Just thought I would share.
    John
    Attached Thumbnails Attached Thumbnails IMG_0240a.jpg   IMG_0241a.jpg   IMG_0242a.jpg   IMG_0243a.jpg
    Newall Microsyn Scale and Reader Head Installation
    Here are a few pictures of my installation on the Newall Microsyn Scale and reader head for the cross slide on my Hardinge HC Chucker.
    I was able to use the dowel pin that held the mechanical stop to attach the scale support bracket. Just made a little adapter bushing and put a slit in it so that it would compress when the bracket nut was tightened.
    I also made an aluminum spacer bracket for the Microsyn Scale that has 2 each countersunk holes with 1/4 X 20 SHCS that screw into a .75 X .75 X .25 thick 1/4 X 20 threaded block that fits into TEE SLOT that was originally used for the Manual Stop. You can see the original mechanical TEE SLOT brackets that were OEM on the Hardinge HC Chucker. I also drilled and tapped 2 each 8/32 holes for mounting the Microsyn Scale to the aluminum spacer bracket.
    The nice thing about this installation is not one hole had to be drilled into the original casting to accomplish this retrofit.
    John
    Attached Thumbnails Attached Thumbnails IMG_0588a.jpg   IMG_0586a.jpg   IMG_0584a.jpg   IMG_0589a.jpg
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  1. Looking For A Digital Readout For Mill Or Lathe. "USED"
    By Fun Police in forum Want To Buy...Need help!
    Last Post: 01-21-2009, 07:22 AM
  2. Tool Room Lathe Chucker (HPCL)
    By HAILINHAAS in forum Haas Lathes
    Last Post: 12-22-2008, 06:38 PM
  3. Scales for a Newall DRO
    By damianks in forum Calibration / Measurement
    Last Post: 06-17-2008, 02:04 AM
  4. Hardinge Chucker Manual
    By leeputman in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2007, 03:44 PM
  5. Hardinge Chucker With Upgrade Tech Cnc
    By MILLMANM in forum Bridgeport / Hardinge Mills
    Last Post: 01-20-2005, 05:45 PM
