603,425 active members*
3,227 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > cog belts that move when spindle changes direction
    May 2007
    58
    What would cause two 60mm wide cog belts to move when the spindle changes direction? Is it, as I assume, as simple in discussion as the motor, and the spindle are not on center? If that is the case how would you verify what direction either one needs to move? Too many questions: Spindle bearings also be a part of it? What are your thoughts?
    It's not what you cut...It's what you don't cut.
    May 2007
    58
    Anyone? Please help.
    Apr 2004
    354
    Sounds like they are not parallel to one another if the belts are moving up and down the pulleys.
    Dec 2008
    3212
    Depends, what speed are you making the spindle reverse ?
    What is the weight the spindle is carrying ? inertia considerations ?
    if at 500 RPM and a small part = no jump
    if at 2000 RPM and large part = yes I would expect belts to bust or at the minimum stretch badly
    Get in the habit of stopping the spindle, before reversing direction,
    and consider the size of the part when tapping for example
  1. Spindle Direction Reversal, How To
    By TacPyro in forum Mach Software (ArtSoft software)
    Last Post: 04-06-2009, 10:40 PM
  2. spindle belts for mori seiki mv35/40
    By brandou10l in forum Uncategorised MetalWorking Machines
    Last Post: 01-06-2008, 12:59 PM
  3. x axis will only move one direction
    By CATCH22 in forum Mach Mill
    Last Post: 12-17-2007, 03:53 AM
  4. Spindle belts
    By wcarrothers1 in forum Bridgeport / Hardinge Mills
    Last Post: 05-19-2007, 07:36 PM
  5. Spindle direction
    By deji in forum Haas Mills
    Last Post: 02-23-2007, 06:53 PM
