588,295 active members*
4,708 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > HOW CAN I CAUSE AN OBJECT TO COMPLETE A ROTATION IN A GIVEN TIME?
    Apr 2006
    59
    I have modelled the Earth moon system in Rhino3d via Rhinoscript.
    But I have no clue how to modify the rotation of the bodies to allow me scale time.
    Can anyone help me please?
    Feb 2008
    586
    I have ZERO Rhino knowledge, but if it were a CNC, I'd look into inverse time feedrates, where F.5 would be 2 seconds (1/2), and F.00001574 would be one day (1/(24*60*60)
    Sep 2004
    264
    You will need something like the Bongo animation plug-in for Rhino which will allow you move objects in space-time and record the movement for playback.
    A crutch in RhinoScript might be to insert Rhino.Sleep(xxx) commands in the script in a loop or somewhere else, which make Rhino suspend for the specified time and then resume. The number in the parentheses is specified in milliseconds. --ch
    Apr 2006
    59
    chmillman, I thank you very much: it worked.
    beege, thank you for posting the cnc help. That will certainly come in useful too.
  1. Need 2D or 3D object Digitized Who can help
    By mattsam in forum Employment Opportunity
    Last Post: 03-15-2008, 01:18 PM
  2. How would you machine this object?
    By xerigen in forum MetalWork Discussion
    Last Post: 10-12-2007, 03:51 AM
  3. okuma 2008 error. DMA transfer does not complete within a specified cycle time.
    By mikul in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-28-2007, 05:36 PM
  4. CAD HELP: 4 lines to 1 box/object how to?
    By FireFghtr in forum Uncategorised CAM Discussion
    Last Post: 02-24-2006, 10:03 PM
  5. pline vs Object
    By flyrc in forum Autodesk
    Last Post: 10-23-2003, 10:28 AM
