586,075 active members*
4,183 visitors online*
    Jun 2006
    44
    Problem with live tools
    I have a problem with the live tooling on my mazak sqt15ms. I used it 2 weeks ago and it worked fine. But now when I try to spin a live tool in either a programme or manually it struggles to spin. it spins for a few seconds, stops, spins for a few seconds, stops, it continues like this for a while and then stops completely and I get Alarm 239 on the screen which is : " Milling Coupling Sensor Malf."
    Has anyone any experience with this ? Do I need to take off the turret and start looking for a sensor ?
    Any help would be appreciated.
    Jun 2008
    150
    Sounds like the driver is not engaging in the driven tool and after two or three tries it alarms out. Hold a block of wood or something against the tooling nut to create drag and see if the coupling drops in and the mill spindle gets up to speed in mdi mode. If it snaps in and you still get the alarm you have a proximity switch problem. If it works, your bearings in the tooling are getting too loose and you'll have to figure a way out to make the tool drag a bit. We put alemite fittings in the tooling and over packed it with grease to create the drag. This was on a 1st version multiplex. They have refined it a lot since those days. We worked with slowing down the speed of the coupling extension by installing a regulator in line to the cylinder so it wouldn't push as hard against the driver thus slip a little and let the driver line up and drop in. The sensors are under the center aluminum center cover and should have led indicators on them when they are made.
    Jun 2006
    44
    Thanks Leelund,
    I took off the aluminium cover from the centre of the turret and saw that one of the proximity sensors was not lighting up when the motor shaft extended so I got a new switch and replaced it. All is working now. Thanks for the info it turned out to be an easy fix and I thought it was going to be a nightmare. Thanks a lot.
    Mark.
  1. BobCad Live Tools?
    By DIFF OVER in forum BobCad-Cam
    Last Post: 03-23-2009, 04:10 PM
  2. Live tools only or Y-Axis?
    By grweldon in forum MetalWork Discussion
    Last Post: 11-19-2008, 03:26 PM
  3. Haas Lathe TL-25B with live tools
    By LONERO in forum Haas Mills
    Last Post: 09-30-2008, 11:52 PM
  4. LOCKING LIVE TOOLS
    By littlerobb in forum Okuma
    Last Post: 09-04-2008, 06:30 PM
  5. threading with live center problem
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 10-31-2005, 03:14 AM
