586,123 active members*
3,360 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Open AutoCad .dwg File in Bobcad v.21?
    Sep 2006
    5
    Is there a way to do this? I haven't been able to. Thanks
    Dec 2008
    4548
    Hi Nat,
    Autodesk has a pretty cool free tool called Design review with an add on called trueview. The trueview should open a dwg and be able to convert it to dxf that V21 can read.
    I have it loaded so if you want me to test it for you first before you download and install it, post a sample dwg and I'll output a dxf to see if you can load it into V21.
    If it works, its pretty cool also as it allows you top annotate and markup drawing without the program, so you could even direct customers to the program to work with you on certain things.
    Anyway look at those 2 programs.
    Sep 2006
    5
    BurrMan,
    Thanks very much for the info., I'll check those out.
    Nat
  1. Dumb AutoCad Question (Open window won't come up)
    By MaxxMan-X in forum Autodesk
    Last Post: 02-28-2011, 08:16 AM
  2. step file into bobcad 21 then into autocad 2000?
    By metlcutr55 in forum BobCad-Cam
    Last Post: 07-17-2009, 12:25 AM
  3. Bobcad Will Not Open.
    By Stampede in forum BobCad-Cam
    Last Post: 10-05-2008, 05:59 AM
  4. Cant open DXF file with mc9.1
    By CATCH22 in forum Mastercam
    Last Post: 01-04-2008, 08:46 PM
  5. BobCad vs Autocad
    By Randy Stevenson in forum BobCad-Cam
    Last Post: 04-07-2006, 05:24 PM
