I picked up an old M-head this weekend. Using the course quill feed requires about 15lbs of breakaway and 12lbs continuous pull at the end of the 8" factory lever. This seems stiff to me. I am thinking I should pull the head apart and see if there is a surface I can hone out to make round again. Thoughts? The pull does seem to be the same throughout the travel so it isn't just one sticky spot.
There is also a collet stuck in the spindle. I have been running penetrating fluid down the drawbar hole a couple times a day for the last two days. Then with the drawbar loosened a turn or two I tap on the top of the draw bar. If I am doing everything correctly, I am only using nut 'A' in the image below. Is there anything I can do with nuts 'B' and 'C' to help with removing the collet? Or what are they for?
Also, it seem the fine quill feed doesn't work or I am doing something wrong. I've tightened the clutch on the left and turned the fine quill feed handle but nothing seems to happen.
Any thoughts, greatly appreciated.
TIA
