586,058 active members*
4,064 visitors online*
Results 1 to 6 of 6
    Sep 2009
    Exclamation NakaMura Tome TMC-30
    I just recently installed a new axis lubrication unit onto this machine. I'm trying to get into the parameters and change the time amount for lubrication. Found the parameters but, it's all number coded... I'm guessing. It shows a number i.e. 0267 and than a binary code i.e. 01101. I'm guessing the first number is the parameter address (What it does) and then the binary part is it's commands. How do I find out the parameter for axis lubrication. I checked all the manuals and surprisingly they don't say anything about the machines 0parameters. Can anyone help?
    Mar 2008
    443
    Call Methods Machine Tools on Monday morning, they'll tell you what the right parameters to change are, and what values to use.
    978-443-5388
    Have your machine's serial number ready when you call!
    Aug 2011
    Nakamura Tome
    What do you need help with?
    I need help too. I resently purchased a used 1992 tmc-35BX with a fanuc OTTC control and I need programing, opearator and maintenance manuals. I do not know if our machines are close enough but it would be great if you could help. I will gladly pay. Don
    Aug 2011
    Nakamura Tome
    Sorry I can not help you with your problem. Howerver I have a problem that maybe you can help me with. I resently purchased a 1992 tmc-35bx with a fancuc OTTC control. I need a operator, maintenace, and program manuals.
    I do not know if you machine is close to the same but it would be great if you could help me out. I will gladly pay.
    Aug 2011
    Aug 2011
    Nakamura Tome
    gavinkong13
    Not sure if you were trying to reply? I only got part of the message.
    [email protected]
  1. Nakamura-Tome TMC-2 Fanuc 3T
    By Leblondmakino in forum Fanuc
    Last Post: 06-10-2012, 06:29 PM
  2. Parameters for Nakamura-Tome TMC-2
    By myhäje in forum MetalWork Discussion
    Last Post: 09-11-2009, 09:40 PM
  3. Nakamura TMC 4 TOME
    By mjblum in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2008, 05:36 PM
  4. Nakamura-Tome Training
    By MaCroB in forum MetalWork Discussion
    Last Post: 09-24-2008, 08:45 PM
  5. Nakamura Tome Question
    By craven12 in forum Uncategorised MetalWorking Machines
    Last Post: 04-22-2008, 08:05 PM
