603,388 active members*
2,725 visitors online*
    Sep 2008
    5
    Need help mach 3 and madcam issues
    I just switched over from using a shopbot control box to a Gecko g540 set of drivers.
    Right now the software I am using is Rhino 4.0 SR6 build 09/07/09 , Madcam 4.1 build 09/08/28 and Mach3 version 3.042.029.
    I am post processing with MACH-3-INCH.TXT. This is my first experience with using Mach 3.
    My problem is that at every square corner I am getting a tapered radius about 1/2 by 1/8" long .
    This happens on every corner as the cutter approaches the corner.
    This does not show up on the rhino drawing or the cut simulator in madcam , nor the simulator in mach 3 but is there on every piece I cut .
    Any body have a clue what might be the cause of this.
    Steve Webster
    35494
    Probably CV mode (G64) . Try running in exact stop mode (G61) and see if it cuts square corners. If it does, then increasing the acceleration will minimize the corner rounding. THE CV docs might be of some help as well.
    http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
    Sep 2008
    5
    Thanks for the quick reply. I'll give it a try.
    Steve
    Sep 2008
    5
    Hey Gerry Thanks for the help. Your suggestion worked perfectly.
    I changed parameters in the cv settings but in the end it was the acceleration rate being higher that gave me square corners.
    Thank you so much.
    Have a big deadline with about 80 sheets for a tv set and I had a shopbot die this week. New gecko drives mach 3 and a client under pressure.
    Saved my bacon
    Steve
  1. Madcam 4th and 5th axis
    By turmite in forum MadCAM
    Last Post: 02-21-2009, 06:37 AM
  2. taig and mach 3 issues
    By diamondback21 in forum Taig Mills / Lathes
    Last Post: 12-24-2008, 07:33 PM
  3. Mach 2 set up issues
    By randyb47 in forum Mach Mill
    Last Post: 11-29-2007, 06:02 AM
  4. How do you use Madcam?
    Last Post: 07-28-2007, 07:12 PM
  5. New US rep for Madcam
    By turmite in forum News Announcements
    Last Post: 07-08-2007, 01:14 AM
