603,355 active members*
3,913 visitors online*
Results 1 to 7 of 7
    Sep 2007
    182
    Lazy Cam Fonts
    Does anyone know of a single line font in LazyCams font database? I have tried many of the fonts that "look" like they should be single line and havent found one yet?
    Or is this a LazyCam setting I am missing?
    Sep 2007
    182
    Nothing? Wow, I thought that was a easy question.....did I not word it correctly?
    35494
    Don't use LazyCAM, but I believe it uses the standard Windows Truetype fonts. Try installing these and see if they work.
    http://www.featurecam.com/general/su...rave_fonts.asp
    35494
    And no, it's not an easy question. It's been asked here hundreds of times, and other then these fonts, there is no easy answer.
    Sep 2007
    182
    Gerry, after seeing the "machine" fonts, I understand why you mention its not an easy question. Thats exactly what I was looking for though, Thank you.
    Feb 2011
    270
    If it is a FONT, it is going to cut an outline of the letters. I found a solution to this problem, by actually creating drawings of different fonts. What I mean, is lines, and arcs drawn in CorelDRAW (a vector-based drawing program), and then grouped together to create each individual letter. I just store the file containing the drawn fonts, and click and drag them into position for any engravings I need lettering for. It's a real tedious way of doing things, and it helps to be a Typographer to get the letter spacing and kerning correct. But the results are beautiful, once they are engraved.
    Oct 2006
    340
    I use the engraving wizard in Mach 3, there are a few single line fonts that work really well. Single line fonts are hard to find unless your willing to pay money for programs like vcarve pro or 2l.
  1. Mach3 Lazy Cam
    By mxtras in forum Mach Mill
    Last Post: 10-14-2009, 05:54 PM
  2. lazy cam problem
    By maupau in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-12-2009, 01:42 PM
  3. Getting to Lazy Cam from Inkscape
    By John Tribe in forum Uncategorised CAM Discussion
    Last Post: 08-22-2008, 12:04 AM
  4. Lazy cam z=60?
    By john robin in forum Mach Plasma / Laser
    Last Post: 11-30-2007, 07:52 PM
  5. lazy cam help
    By andrewbishop66 in forum Mach Wizards, Macros, & Addons
    Last Post: 05-27-2007, 11:05 PM
