587,258 active members*
2,887 visitors online*
Results 1 to 16 of 16
    Nov 2007
    14
    No laser beam?
    Hi all,
    First I want to apoligize for starting a new thread because I have no idea what keywords to use for searching this forum.
    The problem is that unfortunatly our laser cutter/engraving machine stopped cutting in a proces.
    We checked the tube for dark/burned places and or cracks but all seems to be fine!
    We contacted the manufacturer and we both did several tests with no results.
    At last I decided to replace the tube.
    Did a manual laser beam test by pressing the test button on the control panel.
    Viola!, ...it works!!
    Now back to the PC to run a cutting proces. What happens is that the head is moving but without cutting!
    So the machine is now only cutting with the toggle switch in MANUAL mode!
    AUTO mode to control the power by software isn't cutting....
    We also had another PC running the software with no results.
    Anyone any idea about this problem?
    Would be great,
    Moos.
    Dec 2008
    1258
    If your machine has interlocks (safety switches), make sure these are all engaged. On some systems the manual fire overrides these.
    Zax.
    Nov 2007
    14
    Hi Zax,
    As far as I can see there are no other visible switches on the outside of the machine CP for usage. We also did not change any other (dip)switches on the machine PCB's. Same for the cutting software values.
    Only thing we changed/replaced is the laser tube.
    If these interlockes may have changed in a sudden way, do I have to look for hardware or software switches?
    Moos.
    Dec 2008
    1258
    There is probably a switch on the enclosure where the laser tube is located, if this is not making contact it could be the problem.
    The switches in question are hardware.
    On my machine it is possible for the cover to be closed but the switch still doesn't make connection until the lock/latch is engaged.
    Zax.
    Nov 2007
    14
    There are no switches found on the cabin and laser cover.
    Could this be a problem of the power supply itself that feeds the tube or the controller card?
    Moos
    Dec 2008
    1258
    It could be the controller or software, and possibly a wire from the control card to the laser PSU (if it has a parallel wire for the test function).
    Zax.
    Nov 2007
    14
    Thnx Zax,
    So this could be very tricky to trace the fault...
    Moos
    Dec 2008
    1258
    It's possible, but I expect it's something simple and obvious. The machine was working before you opened it up, so I don't think much is wrong.
    Unfortunately some things are difficult to diagnose over the forum, but with some basic fault finding skills it should be easy.
    I would start by locating the laser output signal from the controller (low voltage input to the laser PSU) and checking it. If that isn't working then it is most likely a software or configuration issue.
    Zax.
    Nov 2007
    14
    Okay, we checked the output values from the CC.
    As our CC is the MPC03 we checked the pins 14, 15, 17 and 18 according to scheme.
    14GND 15 Laser output results in 3.3Volts by pressing the Test button on the CP of the machine and toggle is in manual and auto mode. So..
    Manual>Laser fires up (3.3Volts)
    Auto> No laser output (3.3Volts)
    17 and 18 Laser Regulation (in auto mode - software)>
    NO laser output at values below.
    pwr 90> 0.1Volts
    pwr 65>1.17Volts
    pwr 20>2.9Volts
    pwr 0 >3.3Volts
    Have to mention, when stopping the cutting proces the output shows 3.5Volts for all power settings. When running again it shows the above results till it finishes.
    So I think there might be an electric circuit (malfunction) between TP of the centronics on the machine PCB and PSU when controlled by software?
    As you said earlier it overides these when in Manual mode.
    Moos
    May 2005
    31
    SOUNDS LIKE THE SHUTTER NOT OPENING. COULD YOU POSSIBLY HAVE MOISTURE IN YOUR AIRLINE THIS CAUSES THE SHUTTER NOT TO OPEN IN AUTO MODE.
    Nov 2007
    14
    Hmzzz...
    Do you mean this shutter thing is a mechanical part in line with the airline to the nozzle?
    I can't find any specific part, because the airhose is 1 straight tube from the aircompressor to the nozzle.
    Moos
    May 2005
    31
    the shutter atleast on our machines, opens to let the beam thru. on our machine if you have moisture from the aircompresser the machine senses mouisture and will not allow the shutter to open. the shutter kind of works like a camera. i do not know much about engraving machines but im sure its the same concept. what kind of laser is it?
    Nov 2007
    14
    Hi Blinton this is a CO2 laser cutter and engraver.
    This type we have doens't have any shutters.
    May 2005
    31
    what brand machine is it? and age?
    Aug 2008
    82
    If it's a Chinese machine running Lasercut have a look at the layer output (top right of the screen). There is an output checkbox for if you want one of the layers not to output.
    Depending on your screen size/res it may not be fully visible. There is a scroll line under it. Scroll across to the output checkboxes and make sure they are checked.
    With these unchecked there is no laser output on that particular layer but you can still use the test fire feature.
    It could be something a simple as that.
    Good luck
    Dave.
    Nov 2007
    14
    Hi Blinton,
    We are running that setup as Dave describes for 22months now.
    @Dave: As we did the test cutting with different output settings we only use 1 layer (simple circle drawing in lasercut) and of course the output box checked.
    Otherswise the head ins't moving either.
    Moos
  1. Laser Beam alignment
    By graver1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2011, 05:48 AM
  2. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
  3. Column of laser beam...
    By pedroman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-25-2007, 06:34 AM
  4. what is laser beam combiner ?
    By max_imum2000 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-24-2007, 06:31 PM
  5. Laser beam delivery
    By smartcut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2006, 01:55 PM
