586,409 active members*
3,084 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > arrow 1000 alarm code 44-6 - need help
    Oct 2008
    8
    We had servo motor on the "X" axis rebuilt. After installing motor we got alrm code 44-6.
    Cause : the Grid align for the "x" axis completed it's alignment move without finding the marker pulse
    Remedey: check the encoder w/ring and marker pulse setup is located in the Servo Configuration Axis Data the index invert A and index B must be set correctly on the marker. Pulse may be missed
    My question: how do we set Index Invert A & B ?
    Danny Diaz
    [email protected]
    Dec 2007
    159
    Have you tried slowing the feed rate down during the alignment?I get the same error from time to time on one of my Arrows.
    Apr 2009
    32
    I had exactly the same problem before. Solution: Adjust your "TRIM" value of X servro setting. Make it slightly larger to allow servo to travel further while finding marking pulse.
    Hope this helps
  1. Help with Alarm code Arrow 750
    By Joefizz in forum Cincinnati CNC
    Last Post: 07-01-2022, 01:49 PM
  2. Cincinatti Arrow 1000 Down For the Count
    By david_culler in forum Cincinnati CNC
    Last Post: 03-14-2010, 01:22 AM
  3. diagrams cincinati arrow 1000
    By jaimeeduardo in forum Cincinnati CNC
    Last Post: 04-17-2009, 03:30 PM
  4. Arrow 1000 spindle trouble
    By raygun in forum Cincinnati CNC
    Last Post: 03-03-2009, 04:32 AM
  5. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
