586,111 active members*
3,361 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Contour shuttle - press a button & 'Z' goes to preset coordinate?
    Jul 2008
    139
    Subject says it all really, I'd really like to be able to press a button on Shuttle & then the Z plane on my DIY CNC goes to a set location.
    This is becuase when MAch3 promps for a tool change, I have to jog the Z plane up far enough to remove the tool - this is starting to get a bit monotonous now! Far better just to press a button & have it happen.
    I don't have homing switches....perhaps there's some other way I can achieve my goal?
    May 2006
    1469
    One way would be to write a macro and put it in the macro folder. Then call that macro with the Shuttle.
    Greg
    You can set a tool change location that Mach3 will go to automatically when it sees an M6 (I think). Can't check right now, but I think it's on the settings page?
  1. Contour Shuttle in DeskCNC?
    By TheDudeVT in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-07-2013, 01:52 AM
  2. Shuttle Pro and Mach R3.042.020
    By dsage in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2008, 11:27 PM
  3. Replies: 0
    Last Post: 11-11-2008, 02:35 AM
  4. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
    By dsmdude in forum Bending, Forging, Extrusion...
    Last Post: 04-13-2007, 10:01 PM
  5. vfd preset model,what does this mean?
    By CATCH22 in forum Phase Converters
    Last Post: 10-11-2006, 10:54 PM
