588,436 active members*
6,260 visitors online*
Results 1 to 8 of 8
    Aug 2008
    9
    mazatrol t1 errors
    i have a error on a mazatrol t1 . 82 ille. tool no.
    i am very new to using mazatrol and cant get the machine past this alarm signal. can anyone tell me the meaning of this alarm signal.
    24221
    The full description of 82 is Process data entry error - Inapplicable tool Number instruction (No tool assigned).
    Al.
    Albert E.
    Aug 2008
    9
    does the tool number consist of only the turret position? i can see a screen that has the tool description, can there be a problem here which will indicate the same error?
    Aug 2008
    9
    i have another error message, 101 missing condition.
    Sep 2009
    38
    Tool Data
    Hi There;
    Have you register your tools on the tool data file location of the T1 mazatrol.
    Chance are you are missing some imporatant info for the tools on your turret. Go to your program location and select tool data.
    You can also get to the tool data by selecting the menu keys. Make sure you put each tool in correctly.
    If you have the operator manual it can help you in this area. Also the alarm manual has the alarms listed and can tell you exactly what is going on.
    Hope this helps you out some.
    MTSS
    Aug 2008
    9
    thanks for the help. i have moved forward with some of te machines controls but witout a manual i'm a bit in the dark. is there any manuals avaliable on the net? or can i get an example of a simple program from some were?
    Sep 2009
    38
    Mazak T1 Manuals
    Hi Again;
    I have to look around my office area, but I think I may have a General Information manual for programming and tool setup.
    Not certain on the On Line Manual Sources .
    Will e-mail you if I find that manual.
    MTSS
    Sep 2009
    38
    T1 Mazatrol
    Hello There;
    Not sure how far you have got on your control , but I did find a manual that I could send simple programs and other info to you.
    Give me a good e-mail address so I can send you some info that will help you understand the T1 better.
    MTSS
    [email protected]
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Getting 2 Errors.... Someone Please!!
    By DesKitchens in forum Commercial CNC Wood Routers
    Last Post: 09-14-2009, 02:30 PM
  3. x axis errors...help
    By stanglou in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2007, 06:46 AM
  4. Help:possible M/c tool errors
    By bala_51083 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-14-2007, 09:38 PM
