603,890 active members*
4,878 visitors online*
    Jan 2004
    231
    Strange cutting pattern
    Romos, (or others)
    Any ideas why when I cut thicker metal I get the pattern shown here?
    The cut starts by forming a hole, as the cut proceeds it then makes a good clean line.
    I tried adjusting the amount of time the laser gets to start the cut, and I also tried adjusting the pressure of the oxygen.
    What thoughts?
    Owen
    Jul 2004
    28
    This is normal.
    To cut a clean part, use in your file, Lead in/out.
    Jan 2004
    231
    That's discouraging, I didnt know the cut would work that way.
    So you are suggesting making a point of entry into the cut? I give an example of making a circle in my drawing.
    owen
    35494
    Try something like this
    Jul 2004
    28
    Yes.
    Many software can do this.
  1. Having trouble cutting aluminum sheet
    By fastturbovet in forum MetalWork Discussion
    Last Post: 06-15-2005, 04:33 AM
  2. Cutting metal
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 02-20-2005, 06:14 AM
  3. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 04:08 PM
  4. Best tool for cutting metal?
    By PsyKotyk in forum MetalWork Discussion
    Last Post: 04-01-2004, 09:10 AM
  5. Do you account for climb cutting in G code?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 11-07-2003, 02:21 AM
