586,114 active members*
3,310 visitors online*
    Oct 2009
    Setting Size of cutout
    How do you set the size of the cutout you want? Is there a way to just enter the size you want without sizing it with the mouse? I am using Plasma Cam software.
    Apr 2009
    22
    Could you elaborate?
    You can use the scale command. (S) on the key board. Draw a 1" circle then click it to make it green and press "S" then set the base point you want to scale from by clicking the mouse on the screen where you want it to scale from. Then you can either use the mouse to drag it to size or type a scale factor if you put in a factor of 2 it will then be a 2" circle if you put in a factor of .5 it will be a 1/2" circle.
  1. Suction cup beneat your cutout or not?
    By Stonecutter in forum Glass, Plastic and Stone
    Last Post: 12-08-2011, 09:10 PM
  2. How to hold cutout work (n00b question)
    By MechanoMan in forum MetalWork Discussion
    Last Post: 12-27-2008, 04:26 AM
  3. Setting Material Size
    By dgoddard in forum MadCAM
    Last Post: 09-09-2007, 05:07 AM
  4. Photograph cutout for sand casting
    By aircub in forum Employment Opportunity
    Last Post: 01-25-2006, 10:33 PM
