587,773 active members*
3,246 visitors online*
    Feb 2007
    23
    bridgeport CNC R2E4
    I have this message when I press the axes drive key "can not sync with SFP card. link may be dead" and the drivers do not start.
    [email protected]
    Have a Nice day
    Feb 2005
    101
    I actually have the same issue with my R2E4 which I have been chasing for a while.
    Basically this means that the serial link between the BSP2 card and the front panel control is not working properly. In my case the issue is on the BSP2. Based on my previous examination of the control panel PCB I'd say it is less likely there is a problem there since it is very simple stuff.
    Do you have any tools to troubleshoot this type of stuff? Schematics? If you don't have the schematics I can email you a PDF of them.
    James
  1. Bridgeport R2E4
    By steve ohalloran in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2010, 09:11 AM
  2. bridgeport R2E4
    By theguild in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-09-2009, 05:09 AM
  3. bridgeport 9 r2e4
    By reedmiles in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2007, 02:07 AM
  4. bridgeport r2e4
    By najnielkp in forum Bridgeport / Hardinge Mills
    Last Post: 11-05-2006, 11:42 PM
  5. bridgeport 9 r2e4
    By reedmiles in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-30-2005, 03:06 PM
