603,354 active members*
3,078 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > advice on direction control for backgear to mach
    Nov 2007
    19
    Title is kinda confusing.. I have a bp series 1 cnc mill with the backgear .I have a ac drive installed and Mach3 installed.
    Is there a way to tell mach that the spindle is in open or backgear so when it is shifted mach will see this and run the spindle the correct direction? I figured a micro switch at the shift lever but dont know what to do with it. Was told that this wasnt possible but I really cant believe that with all the wizs(sp) around!
    Thanks Jim.
    I posted this in mach mill also...
    Feb 2006
    7063
    Quote Originally Posted by jking View Post
    Thanks Jim.
    When you do pulley setup in Mach3 (Config->SpindlePulleys), in addition to the pulley ratio and desired min/max speeds, each pulley can be flagged as "reversed", which tells Mach3 that the motor direction needs to be reversed when that pulley is selected. This was done specifically to deal with the backgear on most knee mills.
    Regards,
    Ray L.
    Nov 2007
    19
    Thanks Ray
  1. Replies: 0
    Last Post: 10-10-2009, 11:28 PM
  2. c11g vfd direction control
    By doc0302 in forum Automation Technology Products
    Last Post: 08-16-2009, 06:30 AM
  3. Advice/Direction
    By Kaymen in forum Employment Opportunity
    Last Post: 12-22-2008, 10:57 AM
  4. 2.5 Axis Direction Control
    By ee_cnc in forum LinuxCNC (formerly EMC2)
    Last Post: 11-21-2007, 03:42 PM
  5. Problem with Bridgeport backgear
    By navets in forum Bridgeport / Hardinge Mills
    Last Post: 03-06-2006, 08:29 PM
