586,121 active members*
3,721 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Larken > Thinking of Converting my Mill's Anilam Controller to a Larken Based Controller..
    Mar 2007
    304
    Well Group, I've been mulling this over for a while.. converting my SuperMax YMC-30 CNC Milling Machine. It has a working Anilam "Crusader II" controller on it.. but for what I want to do - the controller is memory limited (albeit incredibly functional for a product of the mid 1980's ... hats off to Anilam).
    The Anilam is older (386 based)... and just not able to do what I want to do with the machine (Mainly drop gobs and gobs and gobs of G-code to it.... )
    Therefore I am trying to decide which way to go with the retofit.. Larken, Gecko, etc.
    I have had very good luck with Gecko stepper controllers on lesser powered applications... and I could downgrade the voltage and run Gecko 320's..
    After thinking about it .. I decided not to drop the power to the cnc in favor of the Gecko's ..as I'm like Tim the Toolman - and I always side on things having "More Power".....
    Therefore I started looking at all the aftermarket stuff available to the home DIY'er on a somewhat of a ShoeString budget....
    I am leaning toward the Larken's after calling Larken up and actually talking one on one with Larry Kenny - founder of LarKen .. Larry is incredibly knowledgeable, and has built his controllers for the high powered user. I like that. I want to keep the power going to my servo's.. and keep that table fully moving..
    I'm going to do a very detailed build log and probably put it in a PDF format and put it out on the CNC-Zone, so others can benefit from it.
    Has anyone done a Larken conversion of an Anilam system?
    If so - please contact me here.
    Anxious to get that beast upgraded,
    Joe
    www.CNC-Joe.com
    CNC Is Not Just My Passion.. It's My Addiction !!!!
    Nov 2005
    93
    Yep tons of them here I'm in the middle of one right now. Just search supermax Viper200
    YCM-40 converted from anilam to Mach3 and lovin it.
    Mar 2007
    304
    Thanks CWAugs!
    www.CNC-Joe.com
    Joe, this servo drive review might help you out.
    http://www.thecubestudio.com/ServoDriveReview.htm
    Feb 2007
    966
    CNC-Joe, Check out the Viper Servo forum for more threads on mill conversions.
    http://www.cnczone.com/forums/forumdisplay.php?f=349
    Yes check that out. It was a lovely experiance :tired:
  1. PC Based high-end CNC controller
    By CNCcontrol in forum News Announcements
    Last Post: 05-27-2009, 08:15 PM
  2. Converting DSP controller system to Mach based system.
    By Marwell in forum Machines running Mach Software
    Last Post: 12-20-2008, 12:00 AM
  3. Converting from anilam to pc controller
    By aerofab in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-03-2007, 05:38 PM
  4. Dsp Based mini cnc controller
    By cncadmin in forum News Announcements
    Last Post: 01-05-2005, 01:59 PM
