586,119 active members*
3,465 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Need simple milling & turning sample
Results 1 to 7 of 7
    507
    Talking Need simple milling & turning sample
    Can anyone help me with a simple milling sample program i can use to help me on learning BobCad 18.
    A lathe sample would be also appreciated.
    Upload the sample for others so that all can benefit.
    Klox,
    the edm idiot
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    8
    here is a part that i was trying to make. having trouble getting it to cut right. mike
    Attached Files Attached Files
    :BANNANA:
    Oct 2003
    927
    here's a simple pocket..it's just the tool paths with no offsets. I generate a G-code and use mach3 to set the depth in multipass. Was intended for a !/8" bit.
    I think I do it a hard way though....just tweak the G-code to advance cutter from one path to the next...
    The second txt file G-code is cleaned up a little....still errors but I was in a hurry to get the motor mounted.
    Oct 2003
    927
    Also, here's a motor mount again for 1/8" bit but with offsets in drawing. Mach3 is used again for multipass to cut through a 5/16" aluminum plate. There are two G-codes in the text file....the first is after tweaking and adding ramps...The second is the original from BobCad.......and I still don't know what I'm doing to make it easier.
    507
    Thanx gentleman! I'll take a look....
    *** KloX ***
    Apr 2010
    Hi , Can i get simple milling operation program ? This is very important to my. I am waiting your reply with a program.
    Apr 2010
    sir, I need simple milling operation CNC program. How can I get this ? I think this will supply me from you. So I am waiting your reply with this program as soon as possible. Bye
  1. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
  2. Why would this machine be bad for milling?
    By jevs in forum Knee Vertical Mills
    Last Post: 06-17-2005, 04:49 AM
  3. Heads Up - Article about building CNC Milling Machine
    By samualt in forum Community Club House
    Last Post: 06-13-2005, 08:43 PM
  4. A System For Milling And Turning
    By kathepati in forum FeatureCAM CAD/CAM
    Last Post: 03-21-2005, 04:46 AM
  5. Replies: 6
    Last Post: 01-11-2004, 01:36 AM
