586,106 active members*
3,064 visitors online*
Results 1 to 6 of 6
    Oct 2007
    43
    calibration of x and y axis
    How do I get the proper ratio to calibrate my newly retrofit cnc router?
    When I run multiple cycles, the Y axis seems to move over a little each time, and after a few cycles the parts are out of tolerance. J.P.(group)
    Is this a stepper machine? If it doesn't return to the same position, it's losing or gaining steps.
    Oct 2007
    43
    I have a servo motor system, with encoders mounted directly on the motors.
    Oct 2007
    43
    multicam mg series router gear ratio
    I recently had our multicam router retrofit with a camsoft software setup. I need to find out what the ratio is between the servo motor, and the rack and pinion gear setup, and also the motor and the ball screw. I need to know how many encoder pulses it takes to move 1 inch. Any ideas?
    Jan 2010
    10
    I'm thinking a caliper and some trial and error to get your best fit there, the gear pitch and ratio was probably specific to the old software (if it came with the router, I'm assuming it did) especially if it's an older model before ISO standards. You may have to fudge the programming to get it to run the way you want it, too.
    Jan 2010
    10
    oh, also you can try the data sheet for the specific servo model. Contact either the manufacturer or any other supplier, google search etc, but then again it depends on the length of the pulse input via your software (which you'll need an oscilloscope to measure).
  1. 5-axis rotary calibration
    By tarponicus in forum Calibration / Measurement
    Last Post: 08-13-2011, 02:32 PM
  2. Axis Calibration Issues
    By 2_many_hobbies in forum Mach Mill
    Last Post: 07-06-2009, 02:34 PM
  3. Axis calibration?
    By saabaero in forum Tormach Personal CNC Mill
    Last Post: 06-23-2009, 02:54 PM
  4. x and y axis calibration
    By japco43 in forum DNC Problems and Solutions
    Last Post: 04-27-2009, 08:07 PM
  5. Mach 2 Axis calibration
    By mikie in forum Mach Software (ArtSoft software)
    Last Post: 08-17-2005, 01:19 PM
