586,655 active members*
3,982 visitors online*
Results 1 to 14 of 14
    Oct 2009
    LaserCut 5.3 and CorelDraw 12
    I have problem with lasercut 5.3 plugin for CorelDraw 12. I want to engrave text and then cut it. I make yellow words and black rectangle around them. I set engrave for yellow and black for cutting.
    When i start my machine it engraves letters but then it cuts them (each letter). I tried everything, I transformed text to curves, removed stroke, and nothing it still cuts every letter , when I tell him to cut only rectangles around words.
    Can anybody tell me what should I do?? Thx for help in advance.
    Jul 2008
    776
    Hello,
    May be you can attach this file first and we will check it? If everything will be fine with CDR file, at least we will be sure that reason of problem is in LaserCut.
    Apr 2005
    3634
    Did you try seperate layers, for each operation?
    Free DXF - vectorink.com
    Dec 2008
    1258
    Check that you don't have duplicate text. Select one of the letters and delete it, if it does delete just undo. I have seen this happen when you convert text to curves and the text had either a stroke, or some other effect applied. It can also happen with certain fonts.
    Zax.
    Oct 2009
    Here is my file. I hope it will help in finding solution.
    @Switcher
    Yes I separated text and rectangles. They are in two different layers.
    @zax15uk
    I checked that too everything was fine.
    Attached Files Attached Files
    re:LaserCut 5.3 and CorelDraw 12
    You can analog output before working.
    I had attached the "analog output " button's photo.
    it is on the front of laser cut 5.3 software.
    cici
    I am laser engraving machine manufacture in China.
    I opened your design at laser cut 5.3 software, it looks fine.
    no problem.
    I had attached a new document, a little adjust from your design,
    please test at your software and tell me the result.
    Best Regards,
    Cici
    Feb 2006
    38
    hello,
    i have lasercut 4, is it possible to upgrade on lasercut 5.3;
    laser cut 4 software is too low, so can not upgrade to laser cut 5.3.
    If your machine working well, we do not suggest upgrade.
    because laser cut 5.3 have it is deficiency too.
    Oct 2009
    cicigweike yes it work, but I needed to make it work from corel draw, but I found solution. I export to autocad format in corel and than import in lasercut. It works 100% .
    Hi Micz,
    I had attached our software manual, please check them, you will find all your question's result from this manual.
    I think your driver is MPC6535, but it operation as the same as MPC6515.
    MPC6535 drivers-set up-install path-choose "CorelDraw" from option (AutoCAD, Coreldraw, Laser cut).
    So that you can use Coreldraw output directlly.
    Best Regards,
    Cici
    Feb 2010
    Question i need help
    hi
    i need the lasercut 5.3 software to instal it
    because i lost my cd and my golden sign laser machine is not working ...
    can any one here give me help ?
    my email is [email protected]
    Dec 2009
    26
    ok guys, real stupid question, how are you opening these zip files. i can't get them to open
    Feb 2005
    469
    Quote Originally Posted by adayofjoy View Post
    Do you have WinZip or WinRar? Either one of those programs will open them.
  1. CorelDraw - CorelTrace
    By CJL5585 in forum Uncategorised CAM Discussion
    Last Post: 02-07-2011, 02:05 AM
  2. Lasercut 5.0 & coreldraw problems
    By durtydogg in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-16-2010, 08:48 PM
  3. DXFTool V2 for CorelDRAW is released
    By jemmyell in forum News Announcements
    Last Post: 03-09-2009, 02:43 AM
  4. Is anyone using CorelDraw for artwork??
    By Jeremy_Wittlock in forum DynaTorch
    Last Post: 11-14-2008, 04:46 AM
  5. Tracing Artwork in CorelDRAW
    By jemmyell in forum MetalWork Discussion
    Last Post: 03-10-2008, 04:50 PM
