588,362 active members*
8,194 visitors online*
Thread: Pocket help
Results 1 to 9 of 9
    Dec 2006
    149
    Pocket help
    So I am a complete noob to this stuff and I have this drawing done in BobCAD V21;
    What do I have to do to cut the center pocket? I have selected the piece and used the solid/generate toolpath command but it allows only Planar or spiral or radial toolpath none of which will put the tool in the center of the pocket and mill outwards in a rectangular path.
    Am I doing something wrong here?
    Mar 2005
    368
    You really don't need a model for pocketting.
    Just draw the profile of your pocket.
    Chain select it.
    Select Other>Pocket...>Spiral (the Pocket selection is greyed out until you have a pocket profile preselected)
    If your CAM window is open, you can go right into generating code by setting your roughing/depth parameters then selecting Cut Auto.
    Good luck,
    moldmker
    Dec 2006
    149
    Right but if I am going to draw a cover for something and pocket out the inside how can I obtain the toolpath for the pocket? Do I need to draw the pockets separately?
    Mar 2005
    368
    Whatever you draw, just make sure that it's oriented with the pocket side up when you create the toolpath.
    If you want to draw parts as an assembly, you can use Other>Rotate w/Copy to re-orient parts with machining side up.
    Parts can be on separate layers to turn them on/off.
    Obviously, if pockets are symmetrical, you can just select them thru the top of the lid, but that can be confusing.
    v21 Pocketting relies only on contours, it doesn't look at any surfaces.
    Not sure if this answers your question. Feel free to ask away.
    moldmker
    Dec 2006
    149
    So you are saying I need to draw my parts in stages extracting the Gcode as I go?
    Dec 2008
    4548
    Your pocket is just a 2d operation. The only reason to try and work with 3d is if the walls or floor were tapered or curved somehow.
    This is what you box looks like.
    If you just select the square you need and pocket that, you can set the params you need.
    Mar 2005
    368
    Quote Originally Posted by fourwheeler View Post
    You can draw everything to completion.
    In fact, it's best to have the design finished.
    As you create a toolpath, you can concurrently generate the G-code.
    For me it's easier this way since the path is pre-selected* and ready.
    It can then be placed on a separate layer and blanked.
    This keeps things uncluttered....you'll see.
    You can certainly go thru and create all of the toolpaths first,
    then go back and reselect them for g-code (in fact there are certain times when this is quickest)
    *Note: pre-selection is based on this setting-
    Dec 2006
    149
    Thanks for the tips guys....all help is appreciated.
    But just asking, should I upgrade to V23 now? Is it that much easier to work with?
    Apr 2008
    1577
    LOL, that's a loaded question. I actually have reverted back to V21 for 2d stuff after forcing myself to use only V23 for about 6 months. It's just "faster" for my job shop/limited production environment. I will say that if you are prototyping and your part might change often, V23 will allow you to rewrite code a LOT faster than V21.
  1. Better Way To Pocket In X2?
    By Mastercam User in forum Mastercam
    Last Post: 12-06-2007, 03:44 PM
  2. pocket pc
    By DONNYBRASS in forum MetalWork Discussion
    Last Post: 11-18-2007, 10:02 PM
  3. Open Pocket
    By camtd in forum EdgeCam
    Last Post: 10-23-2006, 07:09 PM
  4. Pocket help
    By tt_raptor_90 in forum Mastercam
    Last Post: 06-20-2006, 03:37 PM
