588,684 active members*
5,984 visitors online*
Thread: Encoders?
Results 1 to 12 of 12
    Jul 2004
    83
    Encoders?
    Which type of encoders does Rutex Servo Drives perfer--
    Incremental or Absolute??
    Aug 2004
    2849
    incremental....
    Oct 2003
    170
    Incrimental and differential
    Jul 2004
    83
    What is the difference between the 2?
    24222
    Basically there are two types of incremental or quadrature encoders, which means there is two wave forms out , (generally square wave) that have a 90deg phase shift between the two (hence quadrature).
    The two types of general outputs are single ended or differential. Single ended means that there is one output per wave form, which can be open collector or with pull up resistor.
    Differential means there is a line driver output which supplies two square wave outputs per waveform, one is the complement of the other. So you end up with four outputs for the two wave forms.
    The benefit of differential is that they are not as prone to noise pickup as single ended are.
    Al
    Albert E.
    Jul 2004
    83
    Is there an "absolute" type of encoder?
    24222
    Absolute encoders typically have 12 bit wide output (or can be serial) but these are less common, the advantage is that the position is retained when powering down, so at power up there is no need to zero reference.
    Al
    Albert E.
    Jul 2004
    83
    Can one use the absolute type of encoders with the rutex system??
    Oct 2003
    170
    No,
    The Rutex system requires only incrimental. Absolute encoders are much much more expensive at the resolutions most of us choose for our systems.
    Tom Eldredge
    Jul 2004
    83
    Thanks Tom, I guess the absolute encoders that I have are useless.
    Jul 2004
    83
    Tom,
    What resolution do Rutex Servo Drives work best at??
    Oct 2003
    170
    Gentlemen,
    I don't see the post here, but I was notified that a customer inquired which resolution the Rutex drives like best. I use 500 line encoders, which gives 2000 steps/rev of the motor. Anything wll work. The drives do not care. 1000 lines is popular too. Keep in mind the speed you want the machine to move. Mach2 can only send out 45000 steps per second. The rutex drives can handle 100,000 steps. The 2000 series will handle 200,000 steps per second. I am hoping I have some to sell in about 3-4 weeks now.
    Tom Eldredge
    rutex LLC
  1. Inconsistent (?) instructions for wiring encoders
    By InsaneEPP in forum Servo Drives
    Last Post: 02-25-2005, 08:04 PM
  2. can I use these encoders
    By cncpete in forum CNC Machine Related Electronics
    Last Post: 09-29-2004, 07:33 AM
  3. Renco open end encoders
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 03-23-2004, 04:52 PM
  4. Stepper motors, encoders...
    By runnoahrun in forum CNC Machine Related Electronics
    Last Post: 02-29-2004, 04:59 AM
  5. encoders with steppers
    By turmite in forum CNC Machine Related Electronics
    Last Post: 02-01-2004, 03:44 AM
