Someone somewhere has said that SprutCAM is compatible with Windows 7. I need a bit more info, please.
Is SprutCAM compatible with both 32 and 64 bit versions of Windows 7 or only with the 32 bit version? If the answer is 32 bit only, will Sprut run in the XP compatibility mode on a 64 bit system?
On a related topic, Microsoft says that home versions of Windows 7 are not eligible for a free download of the XP compatibility mode. You can only have it if you upgrade to the (more expensive) professional version. If I somehow manage to get a copy of the XP compatibility mode software, can it be installed on a home version of Windows 7?
Thanks in advance.
