586,903 active members*
2,814 visitors online*
Results 1 to 19 of 19
    Mar 2007
    62
    having issues with a program
    I am trying to run a new program on the machine and when I load the g code an error message pops up in the status bar "radius from end of arc differs from radius to start line 12" I had a problem like this in the past and Tommy solved it for me. I can not get ahold of him right now. Anybody have any ideas. Thanks
    Feb 2006
    794
    What the message is saying is the distance relationship between start and end point do not match the I & J's of your arc's R value. So, what you will have to do is calculate your arc point to both so that the the I's & J's are in proper relationship to your R value. This is what keeps the arc the same distance from center of arc all the way through the arc. It is easier done than said ! Just get out your calculator and crunch some numbers and it won't take long and you will know what I am trying to say here.
    Don
    Don
    IH v-3 early model owner
    Mar 2007
    62
    Thanks for that info. I am not sure if that is the problem. Last time I had something like this happen Tommy said it is a common error and had me go and change a setting somewhere. Changed the setting and no problems, until now. Thanks
    Feb 2008
    586
    Make sure that if you go from linear to circular and back again, that you include a G01 or G02/3 depending. Many times an error like that is because you have:
    G02X###Y###R###F###
    Y####
    The "Y" line would need a G01 (if it is in fact a linear move)
    What is the machine, and what is the controller? Could you also post the code where it errors out?
    Mar 2007
    62
    ( Produced :- 17:38:12 Tuesday, December 01, 2009 )
    ( CNC File :- lathe chuck back plate )
    ( Post Processor :- M_MACH3 )
    ( Part Number ID :- )
    N5G00G21G17G90G40G49G80
    N6G49
    N7T1M06 ( End Mill )
    N8G00G43Z50.0H1
    N9S3450M03
    N10G94
    N11Z3.0
    N12G01Z-2.0F100
    N13G03X-1.791Y1.791I-1.791J0.0F50
    N14X-3.581Y0.0I-1.791J0.0
    N15X0.0Y-3.581I0.0J0.0
    N16X3.581Y0.0I0.0J0.0
    N17X-1.791Y5.372I-1.791J0.0
    N18X-7.163Y0.0I-1.791J0.0
    N19X0.0Y-7.163I0.0J0.0
    N20X7.163Y0.0I0.0J0.0
    N21X-1.791Y8.953I-1.791J0.0
    N22X-10.744Y0.0I-1.791J0.0
    N23X0.0Y-10.744I0.0J0.0
    N24X10.744Y0.0I0.0J0.0
    N25X-1.791Y12.534I-1.791J0.0
    N26X-14.325Y0.0I-1.791J0.0
    N27X0.0Y-14.325I0.0J0.0
    N28X14.325Y0.0I0.0J0.0
    N29X0.0Y14.325I0.0J0.0
    N30X-14.325Y0.0I0.0J0.0
    N31X-7.163Y-7.163I-7.163J0.0
    N32X0.0Y0.0I-7.163J0.0
    N33G01Z-4.0F100
    N34G03X-1.791Y1.791I-1.791J0.0F50
    N35X-3.581Y0.0I-1.791J0.0
    N36X0.0Y-3.581I0.0J0.0
    N37X3.581Y0.0I0.0J0.0
    N38X-1.791Y5.372I-1.791J0.0
    N39X-7.163Y0.0I-1.791J0.0
    N40X0.0Y-7.163I0.0J0.0
    N41X7.163Y0.0I0.0J0.0
    N42X-1.791Y8.953I-1.791J0.0
    N43X-10.744Y0.0I-1.791J0.0
    N44X0.0Y-10.744I0.0J0.0
    N45X10.744Y0.0I0.0J0.0
    N46X-1.791Y12.534I-1.791J0.0
    N47X-14.325Y0.0I-1.791J0.0
    N48X0.0Y-14.325I0.0J0.0
    N49X14.325Y0.0I0.0J0.0
    N50X0.0Y14.325I0.0J0.0
    N51X-14.325Y0.0I0.0J0.0
    N52X-7.163Y-7.163I-7.163J0.0
    N53X0.0Y0.0I-7.163J0.0
    N54G01Z-6.0F100
    N55G03X-1.791Y1.791I-1.791J0.0F50
    N56X-3.581Y0.0I-1.791J0.0
    N57X0.0Y-3.581I0.0J0.0
    N58X3.581Y0.0I0.0J0.0
    N59X-1.791Y5.372I-1.791J0.0
    N60X-7.163Y0.0I-1.791J0.0
    N61X0.0Y-7.163I0.0J0.0
    N62X7.163Y0.0I0.0J0.0
    N63X-1.791Y8.953I-1.791J0.0
    N64X-10.744Y0.0I-1.791J0.0
    N65X0.0Y-10.744I0.0J0.0
    N66X10.744Y0.0I0.0J0.0
    N67X-1.791Y12.534I-1.791J0.0
    N68X-14.325Y0.0I-1.791J0.0
    N69X0.0Y-14.325I0.0J0.0
    N70X14.325Y0.0I0.0J0.0
    N71X0.0Y14.325I0.0J0.0
    N72X-14.325Y0.0I0.0J0.0
    N73X-7.163Y-7.163I-7.163J0.0
    N74X0.0Y0.0I-7.163J0.0
    N75G01Z-8.0F100
    N76G03X-1.791Y1.791I-1.791J0.0F50
    N77X-3.581Y0.0I-1.791J0.0
    N78X0.0Y-3.581I0.0J0.0
    N79X3.581Y0.0I0.0J0.0
    N80X-1.791Y5.372I-1.791J0.0
    N81X-7.163Y0.0I-1.791J0.0
    N82X0.0Y-7.163I0.0J0.0
    N83X7.163Y0.0I0.0J0.0
    N84X-1.791Y8.953I-1.791J0.0
    N85X-10.744Y0.0I-1.791J0.0
    N86X0.0Y-10.744I0.0J0.0
    N87X10.744Y0.0I0.0J0.0
    N88X-1.791Y12.534I-1.791J0.0
    N89X-14.325Y0.0I-1.791J0.0
    N90X0.0Y-14.325I0.0J0.0
    N91X14.325Y0.0I0.0J0.0
    N92X0.0Y14.325I0.0J0.0
    N93X-14.325Y0.0I0.0J0.0
    N94X-7.163Y-7.163I-7.163J0.0
    N95X0.0Y0.0I-7.163J0.0
    N96G01Z-10.0F100
    N97G03X-1.791Y1.791I-1.791J0.0F50
    N98X-3.581Y0.0I-1.791J0.0
    N99X0.0Y-3.581I0.0J0.0
    N100X3.581Y0.0I0.0J0.0
    N101X-1.791Y5.372I-1.791J0.0
    N102X-7.163Y0.0I-1.791J0.0
    N103X0.0Y-7.163I0.0J0.0
    N104X7.163Y0.0I0.0J0.0
    N105X-1.791Y8.953I-1.791J0.0
    N106X-10.744Y0.0I-1.791J0.0
    N107X0.0Y-10.744I0.0J0.0
    N108X10.744Y0.0I0.0J0.0
    N109X-1.791Y12.534I-1.791J0.0
    N110X-14.325Y0.0I-1.791J0.0
    N111X0.0Y-14.325I0.0J0.0
    N112X14.325Y0.0I0.0J0.0
    N113X0.0Y14.325I0.0J0.0
    N114X-14.325Y0.0I0.0J0.0
    N115X-7.163Y-7.163I-7.163J0.0
    N116X0.0Y0.0I-7.163J0.0
    N117G01Z-12.0F100
    N118G03X-1.791Y1.791I-1.791J0.0F50
    N119X-3.581Y0.0I-1.791J0.0
    N120X0.0Y-3.581I0.0J0.0
    N121X3.581Y0.0I0.0J0.0
    N122X-1.791Y5.372I-1.791J0.0
    N123X-7.163Y0.0I-1.791J0.0
    N124X0.0Y-7.163I0.0J0.0
    N125X7.163Y0.0I0.0J0.0
    N126X-1.791Y8.953I-1.791J0.0
    N127X-10.744Y0.0I-1.791J0.0
    N128X0.0Y-10.744I0.0J0.0
    N129X10.744Y0.0I0.0J0.0
    N130X-1.791Y12.534I-1.791J0.0
    N131X-14.325Y0.0I-1.791J0.0
    N132X0.0Y-14.325I0.0J0.0
    N133X14.325Y0.0I0.0J0.0
    N134X0.0Y14.325I0.0J0.0
    N135X-14.325Y0.0I0.0J0.0
    N136X-7.163Y-7.163I-7.163J0.0
    N137X0.0Y0.0I-7.163J0.0
    N138G01Z-14.0F100
    N139G03X-1.791Y1.791I-1.791J0.0F50
    N140X-3.581Y0.0I-1.791J0.0
    N141X0.0Y-3.581I0.0J0.0
    N142X3.581Y0.0I0.0J0.0
    N143X-1.791Y5.372I-1.791J0.0
    N144X-7.163Y0.0I-1.791J0.0
    N145X0.0Y-7.163I0.0J0.0
    N146X7.163Y0.0I0.0J0.0
    N147X-1.791Y8.953I-1.791J0.0
    N148X-10.744Y0.0I-1.791J0.0
    N149X0.0Y-10.744I0.0J0.0
    N150X10.744Y0.0I0.0J0.0
    N151X-1.791Y12.534I-1.791J0.0
    N152X-14.325Y0.0I-1.791J0.0
    N153X0.0Y-14.325I0.0J0.0
    N154X14.325Y0.0I0.0J0.0
    N155X0.0Y14.325I0.0J0.0
    N156X-14.325Y0.0I0.0J0.0
    N157X-7.163Y-7.163I-7.163J0.0
    N158X0.0Y0.0I-7.163J0.0
    N159G01Z-16.0F100
    N160G03X-1.791Y1.791I-1.791J0.0F50
    N161X-3.581Y0.0I-1.791J0.0
    N162X0.0Y-3.581I0.0J0.0
    N163X3.581Y0.0I0.0J0.0
    N164X-1.791Y5.372I-1.791J0.0
    N165X-7.163Y0.0I-1.791J0.0
    N166X0.0Y-7.163I0.0J0.0
    N167X7.163Y0.0I0.0J0.0
    N168X-1.791Y8.953I-1.791J0.0
    N169X-10.744Y0.0I-1.791J0.0
    N170X0.0Y-10.744I0.0J0.0
    N171X10.744Y0.0I0.0J0.0
    N172X-1.791Y12.534I-1.791J0.0
    N173X-14.325Y0.0I-1.791J0.0
    N174X0.0Y-14.325I0.0J0.0
    N175X14.325Y0.0I0.0J0.0
    N176X0.0Y14.325I0.0J0.0
    N177X-14.325Y0.0I0.0J0.0
    N178X-7.163Y-7.163I-7.163J0.0
    N179X0.0Y0.0I-7.163J0.0
    N180G01Z-18.0F100
    N181G03X-1.791Y1.791I-1.791J0.0F50
    N182X-3.581Y0.0I-1.791J0.0
    N183X0.0Y-3.581I0.0J0.0
    N184X3.581Y0.0I0.0J0.0
    N185X-1.791Y5.372I-1.791J0.0
    N186X-7.163Y0.0I-1.791J0.0
    N187X0.0Y-7.163I0.0J0.0
    N188X7.163Y0.0I0.0J0.0
    N189X-1.791Y8.953I-1.791J0.0
    N190X-10.744Y0.0I-1.791J0.0
    N191X0.0Y-10.744I0.0J0.0
    N192X10.744Y0.0I0.0J0.0
    N193X-1.791Y12.534I-1.791J0.0
    N194X-14.325Y0.0I-1.791J0.0
    N195X0.0Y-14.325I0.0J0.0
    N196X14.325Y0.0I0.0J0.0
    N197X0.0Y14.325I0.0J0.0
    N198X-14.325Y0.0I0.0J0.0
    N199X-7.163Y-7.163I-7.163J0.0
    N200X0.0Y0.0I-7.163J0.0
    N201G01Z-20.0F100
    N202G03X-1.791Y1.791I-1.791J0.0F50
    N203X-3.581Y0.0I-1.791J0.0
    N204X0.0Y-3.581I0.0J0.0
    N205X3.581Y0.0I0.0J0.0
    N206X-1.791Y5.372I-1.791J0.0
    N207X-7.163Y0.0I-1.791J0.0
    N208X0.0Y-7.163I0.0J0.0
    N209X7.163Y0.0I0.0J0.0
    N210X-1.791Y8.953I-1.791J0.0
    N211X-10.744Y0.0I-1.791J0.0
    N212X0.0Y-10.744I0.0J0.0
    N213X10.744Y0.0I0.0J0.0
    N214X-1.791Y12.534I-1.791J0.0
    N215X-14.325Y0.0I-1.791J0.0
    N216X0.0Y-14.325I0.0J0.0
    N217X14.325Y0.0I0.0J0.0
    N218X0.0Y14.325I0.0J0.0
    N219X-14.325Y0.0I0.0J0.0
    N220X-7.163Y-7.163I-7.163J0.0
    N221X0.0Y0.0I-7.163J0.0
    N222G00Z3.0
    N223Z50.0
    N224Z3.0
    N225G01Z-2.0F100
    N226G03X-2.038Y2.038I-2.038J0.0F50
    N227X-4.075Y0.0I-2.038J0.0
    N228X0.0Y-4.075I0.0J0.0
    N229X4.075Y0.0I0.0J0.0
    N230X-2.038Y6.113I-2.038J0.0
    N231X-8.15Y0.0I-2.038J0.0
    N232X0.0Y-8.15I0.0J0.0
    N233X8.15Y0.0I0.0J0.0
    N234X-2.038Y10.188I-2.038J0.0
    N235X-12.225Y0.0I-2.038J0.0
    N236X0.0Y-12.225I0.0J0.0
    N237X12.225Y0.0I0.0J0.0
    N238X-2.038Y14.263I-2.038J0.0
    N239X-16.3Y0.0I-2.038J0.0
    N240X0.0Y-16.3I0.0J0.0
    N241X16.3Y0.0I0.0J0.0
    N242X-2.038Y18.338I-2.038J0.0
    N243X-20.375Y0.0I-2.038J0.0
    N244X0.0Y-20.375I0.0J0.0
    N245X20.375Y0.0I0.0J0.0
    N246X-2.038Y22.413I-2.038J0.0
    N247X-24.45Y0.0I-2.038J0.0
    N248X0.0Y-24.45I0.0J0.0
    N249X24.45Y0.0I0.0J0.0
    N250X-2.038Y26.488I-2.038J0.0
    N251X-28.525Y0.0I-2.038J0.0
    N252X0.0Y-28.525I0.0J0.0
    N253X28.525Y0.0I0.0J0.0
    N254X-2.038Y30.563I-2.038J0.0
    N255X-32.6Y0.0I-2.038J0.0
    N256X0.0Y-32.6I0.0J0.0
    N257X32.6Y0.0I0.0J0.0
    N258X-2.038Y34.638I-2.038J0.0
    N259X-36.675Y0.0I-2.038J0.0
    N260X0.0Y-36.675I0.0J0.0
    N261X36.675Y0.0I0.0J0.0
    N262X-2.038Y38.713I-2.038J0.0
    N263X-40.75Y0.0I-2.038J0.0
    N264X0.0Y-40.75I0.0J0.0
    N265X40.75Y0.0I0.0J0.0
    N266X-2.038Y42.788I-2.038J0.0
    N267X-44.825Y0.0I-2.038J0.0
    N268X0.0Y-44.825I0.0J0.0
    N269X44.825Y0.0I0.0J0.0
    N270X0.0Y44.825I0.0J0.0
    N271X-44.825Y0.0I0.0J0.0
    N272X-22.413Y-22.413I-22.413J0.0
    N273X0.0Y0.0I-22.413J0.0
    N274G01Z-4.0F100
    N275G03X-2.038Y2.038I-2.038J0.0F50
    N276X-4.075Y0.0I-2.038J0.0
    N277X0.0Y-4.075I0.0J0.0
    N278X4.075Y0.0I0.0J0.0
    N279X-2.038Y6.113I-2.038J0.0
    N280X-8.15Y0.0I-2.038J0.0
    N281X0.0Y-8.15I0.0J0.0
    N282X8.15Y0.0I0.0J0.0
    N283X-2.038Y10.188I-2.038J0.0
    N284X-12.225Y0.0I-2.038J0.0
    N285X0.0Y-12.225I0.0J0.0
    N286X12.225Y0.0I0.0J0.0
    N287X-2.038Y14.263I-2.038J0.0
    N288X-16.3Y0.0I-2.038J0.0
    N289X0.0Y-16.3I0.0J0.0
    N290X16.3Y0.0I0.0J0.0
    N291X-2.038Y18.338I-2.038J0.0
    N292X-20.375Y0.0I-2.038J0.0
    N293X0.0Y-20.375I0.0J0.0
    N294X20.375Y0.0I0.0J0.0
    N295X-2.038Y22.413I-2.038J0.0
    N296X-24.45Y0.0I-2.038J0.0
    N297X0.0Y-24.45I0.0J0.0
    N298X24.45Y0.0I0.0J0.0
    N299X-2.038Y26.488I-2.038J0.0
    N300X-28.525Y0.0I-2.038J0.0
    N301X0.0Y-28.525I0.0J0.0
    N302X28.525Y0.0I0.0J0.0
    N303X-2.038Y30.563I-2.038J0.0
    N304X-32.6Y0.0I-2.038J0.0
    N305X0.0Y-32.6I0.0J0.0
    N306X32.6Y0.0I0.0J0.0
    N307X-2.038Y34.638I-2.038J0.0
    N308X-36.675Y0.0I-2.038J0.0
    N309X0.0Y-36.675I0.0J0.0
    N310X36.675Y0.0I0.0J0.0
    N311X-2.038Y38.713I-2.038J0.0
    N312X-40.75Y0.0I-2.038J0.0
    N313X0.0Y-40.75I0.0J0.0
    N314X40.75Y0.0I0.0J0.0
    N315X-2.038Y42.788I-2.038J0.0
    N316X-44.825Y0.0I-2.038J0.0
    N317X0.0Y-44.825I0.0J0.0
    N318X44.825Y0.0I0.0J0.0
    N319X0.0Y44.825I0.0J0.0
    N320X-44.825Y0.0I0.0J0.0
    N321X-22.413Y-22.413I-22.413J0.0
    N322X0.0Y0.0I-22.413J0.0
    N323G00Z3.0
    N324Z50.0
    N325X90.0Y0.0
    N326Z3.0
    N327G01Z-2.0F100
    N328G03X89.088Y0.913I89.088J0.0F50
    N329X88.175Y0.0I89.088J0.0
    N330X90.0Y-1.825I90.0J0.0
    N331X91.825Y0.0I90.0J0.0
    N332X90.0Y1.825I90.0J0.0
    N333X88.175Y0.0I90.0J0.0
    N334X89.088Y-0.913I89.088J0.0
    N335X90.0Y0.0I89.088J0.0
    N336G01Z-4.0F100
    N337G03X89.088Y0.913I89.088J0.0F50
    N338X88.175Y0.0I89.088J0.0
    N339X90.0Y-1.825I90.0J0.0
    N340X91.825Y0.0I90.0J0.0
    N341X90.0Y1.825I90.0J0.0
    N342X88.175Y0.0I90.0J0.0
    N343X89.088Y-0.913I89.088J0.0
    N344X90.0Y0.0I89.088J0.0
    N345G01Z-6.0F100
    N346G03X89.088Y0.913I89.088J0.0F50
    N347X88.175Y0.0I89.088J0.0
    N348X90.0Y-1.825I90.0J0.0
    N349X91.825Y0.0I90.0J0.0
    N350X90.0Y1.825I90.0J0.0
    N351X88.175Y0.0I90.0J0.0
    N352X89.088Y-0.913I89.088J0.0
    N353X90.0Y0.0I89.088J0.0
    N354G01Z-8.0F100
    N355G03X89.088Y0.913I89.088J0.0F50
    N356X88.175Y0.0I89.088J0.0
    N357X90.0Y-1.825I90.0J0.0
    N358X91.825Y0.0I90.0J0.0
    N359X90.0Y1.825I90.0J0.0
    N360X88.175Y0.0I90.0J0.0
    N361X89.088Y-0.913I89.088J0.0
    N362X90.0Y0.0I89.088J0.0
    N363G01Z-10.0F100
    N364G03X89.088Y0.913I89.088J0.0F50
    N365X88.175Y0.0I89.088J0.0
    N366X90.0Y-1.825I90.0J0.0
    N367X91.825Y0.0I90.0J0.0
    N368X90.0Y1.825I90.0J0.0
    N369X88.175Y0.0I90.0J0.0
    N370X89.088Y-0.913I89.088J0.0
    N371X90.0Y0.0I89.088J0.0
    N372G01Z-12.0F100
    N373G03X89.088Y0.913I89.088J0.0F50
    N374X88.175Y0.0I89.088J0.0
    N375X90.0Y-1.825I90.0J0.0
    N376X91.825Y0.0I90.0J0.0
    N377X90.0Y1.825I90.0J0.0
    N378X88.175Y0.0I90.0J0.0
    N379X89.088Y-0.913I89.088J0.0
    N380X90.0Y0.0I89.088J0.0
    N381G01Z-14.0F100
    N382G03X89.088Y0.913I89.088J0.0F50
    N383X88.175Y0.0I89.088J0.0
    N384X90.0Y-1.825I90.0J0.0
    N385X91.825Y0.0I90.0J0.0
    N386X90.0Y1.825I90.0J0.0
    N387X88.175Y0.0I90.0J0.0
    N388X89.088Y-0.913I89.088J0.0
    N389X90.0Y0.0I89.088J0.0
    N390G01Z-16.0F100
    N391G03X89.088Y0.913I89.088J0.0F50
    N392X88.175Y0.0I89.088J0.0
    N393X90.0Y-1.825I90.0J0.0
    N394X91.825Y0.0I90.0J0.0
    N395X90.0Y1.825I90.0J0.0
    N396X88.175Y0.0I90.0J0.0
    N397X89.088Y-0.913I89.088J0.0
    N398X90.0Y0.0I89.088J0.0
    N399G01Z-18.0F100
    N400G03X89.088Y0.913I89.088J0.0F50
    N401X88.175Y0.0I89.088J0.0
    N402X90.0Y-1.825I90.0J0.0
    N403X91.825Y0.0I90.0J0.0
    N404X90.0Y1.825I90.0J0.0
    N405X88.175Y0.0I90.0J0.0
    N406X89.088Y-0.913I89.088J0.0
    N407X90.0Y0.0I89.088J0.0
    N408G01Z-20.0F100
    N409G03X89.088Y0.913I89.088J0.0F50
    N410X88.175Y0.0I89.088J0.0
    N411X90.0Y-1.825I90.0J0.0
    N412X91.825Y0.0I90.0J0.0
    N413X90.0Y1.825I90.0J0.0
    N414X88.175Y0.0I90.0J0.0
    N415X89.088Y-0.913I89.088J0.0
    N416X90.0Y0.0I89.088J0.0
    N417G00Z3.0
    N418Z50.0
    N419Z3.0
    N420G01Z-1.75F100
    N421G03X87.838Y2.163I87.838J0.0F50
    N422X85.675Y0.0I87.838J0.0
    N423X90.0Y-4.325I90.0J0.0
    N424X94.325Y0.0I90.0J0.0
    N425X90.0Y4.325I90.0J0.0
    N426X85.675Y0.0I90.0J0.0
    N427X87.838Y-2.163I87.838J0.0
    N428X90.0Y0.0I87.838J0.0
    N429G01Z-3.5F100
    N430G03X87.838Y2.163I87.838J0.0F50
    N431X85.675Y0.0I87.838J0.0
    N432X90.0Y-4.325I90.0J0.0
    N433X94.325Y0.0I90.0J0.0
    N434X90.0Y4.325I90.0J0.0
    N435X85.675Y0.0I90.0J0.0
    N436X87.838Y-2.163I87.838J0.0
    N437X90.0Y0.0I87.838J0.0
    N438G01Z-5.25F100
    N439G03X87.838Y2.163I87.838J0.0F50
    N440X85.675Y0.0I87.838J0.0
    N441X90.0Y-4.325I90.0J0.0
    N442X94.325Y0.0I90.0J0.0
    N443X90.0Y4.325I90.0J0.0
    N444X85.675Y0.0I90.0J0.0
    N445X87.838Y-2.163I87.838J0.0
    N446X90.0Y0.0I87.838J0.0
    N447G01Z-7.0F100
    N448G03X87.838Y2.163I87.838J0.0F50
    N449X85.675Y0.0I87.838J0.0
    N450X90.0Y-4.325I90.0J0.0
    N451X94.325Y0.0I90.0J0.0
    N452X90.0Y4.325I90.0J0.0
    N453X85.675Y0.0I90.0J0.0
    N454X87.838Y-2.163I87.838J0.0
    N455X90.0Y0.0I87.838J0.0
    N456G01Z-8.75F100
    N457G03X87.838Y2.163I87.838J0.0F50
    N458X85.675Y0.0I87.838J0.0
    N459X90.0Y-4.325I90.0J0.0
    N460X94.325Y0.0I90.0J0.0
    N461X90.0Y4.325I90.0J0.0
    N462X85.675Y0.0I90.0J0.0
    N463X87.838Y-2.163I87.838J0.0
    N464X90.0Y0.0I87.838J0.0
    N465G01Z-10.5F100
    N466G03X87.838Y2.163I87.838J0.0F50
    N467X85.675Y0.0I87.838J0.0
    N468X90.0Y-4.325I90.0J0.0
    N469X94.325Y0.0I90.0J0.0
    N470X90.0Y4.325I90.0J0.0
    N471X85.675Y0.0I90.0J0.0
    N472X87.838Y-2.163I87.838J0.0
    N473X90.0Y0.0I87.838J0.0
    N474G00Z3.0
    N475Z50.0
    N476X-45.0Y-77.942
    N477Z3.0
    N478G01Z-1.75F100
    N479G03X-47.163Y-75.78I-47.163J-77.942F50
    N480X-49.325Y-77.942I-47.163J-77.942
    N481X-45.0Y-82.267I-45.0J-77.942
    N482X-40.675Y-77.942I-45.0J-77.942
    N483X-45.0Y-73.617I-45.0J-77.942
    N484X-49.325Y-77.942I-45.0J-77.942
    N485X-47.163Y-80.105I-47.163J-77.942
    N486X-45.0Y-77.942I-47.163J-77.942
    N487G01Z-3.5F100
    N488G03X-47.163Y-75.78I-47.163J-77.942F50
    N489X-49.325Y-77.942I-47.163J-77.942
    N490X-45.0Y-82.267I-45.0J-77.942
    N491X-40.675Y-77.942I-45.0J-77.942
    N492X-45.0Y-73.617I-45.0J-77.942
    N493X-49.325Y-77.942I-45.0J-77.942
    N494X-47.163Y-80.105I-47.163J-77.942
    N495X-45.0Y-77.942I-47.163J-77.942
    N496G01Z-5.25F100
    N497G03X-47.163Y-75.78I-47.163J-77.942F50
    N498X-49.325Y-77.942I-47.163J-77.942
    N499X-45.0Y-82.267I-45.0J-77.942
    N500X-40.675Y-77.942I-45.0J-77.942
    N501X-45.0Y-73.617I-45.0J-77.942
    N502X-49.325Y-77.942I-45.0J-77.942
    N503X-47.163Y-80.105I-47.163J-77.942
    N504X-45.0Y-77.942I-47.163J-77.942
    N505G01Z-7.0F100
    N506G03X-47.163Y-75.78I-47.163J-77.942F50
    N507X-49.325Y-77.942I-47.163J-77.942
    N508X-45.0Y-82.267I-45.0J-77.942
    N509X-40.675Y-77.942I-45.0J-77.942
    N510X-45.0Y-73.617I-45.0J-77.942
    N511X-49.325Y-77.942I-45.0J-77.942
    N512X-47.163Y-80.105I-47.163J-77.942
    N513X-45.0Y-77.942I-47.163J-77.942
    N514G01Z-8.75F100
    N515G03X-47.163Y-75.78I-47.163J-77.942F50
    N516X-49.325Y-77.942I-47.163J-77.942
    N517X-45.0Y-82.267I-45.0J-77.942
    N518X-40.675Y-77.942I-45.0J-77.942
    N519X-45.0Y-73.617I-45.0J-77.942
    N520X-49.325Y-77.942I-45.0J-77.942
    N521X-47.163Y-80.105I-47.163J-77.942
    N522X-45.0Y-77.942I-47.163J-77.942
    N523G01Z-10.5F100
    N524G03X-47.163Y-75.78I-47.163J-77.942F50
    N525X-49.325Y-77.942I-47.163J-77.942
    N526X-45.0Y-82.267I-45.0J-77.942
    N527X-40.675Y-77.942I-45.0J-77.942
    N528X-45.0Y-73.617I-45.0J-77.942
    N529X-49.325Y-77.942I-45.0J-77.942
    N530X-47.163Y-80.105I-47.163J-77.942
    N531X-45.0Y-77.942I-47.163J-77.942
    N532G00Z3.0
    N533Z50.0
    N534Z3.0
    N535G01Z-2.0F100
    N536G03X-45.913Y-77.03I-45.913J-77.942F50
    N537X-46.825Y-77.942I-45.913J-77.942
    N538X-45.0Y-79.767I-45.0J-77.942
    N539X-43.175Y-77.942I-45.0J-77.942
    N540X-45.0Y-76.117I-45.0J-77.942
    N541X-46.825Y-77.942I-45.0J-77.942
    N542X-45.913Y-78.855I-45.913J-77.942
    N543X-45.0Y-77.942I-45.913J-77.942
    N544G01Z-4.0F100
    N545G03X-45.913Y-77.03I-45.913J-77.942F50
    N546X-46.825Y-77.942I-45.913J-77.942
    N547X-45.0Y-79.767I-45.0J-77.942
    N548X-43.175Y-77.942I-45.0J-77.942
    N549X-45.0Y-76.117I-45.0J-77.942
    N550X-46.825Y-77.942I-45.0J-77.942
    N551X-45.913Y-78.855I-45.913J-77.942
    N552X-45.0Y-77.942I-45.913J-77.942
    N553G01Z-6.0F100
    N554G03X-45.913Y-77.03I-45.913J-77.942F50
    N555X-46.825Y-77.942I-45.913J-77.942
    N556X-45.0Y-79.767I-45.0J-77.942
    N557X-43.175Y-77.942I-45.0J-77.942
    N558X-45.0Y-76.117I-45.0J-77.942
    N559X-46.825Y-77.942I-45.0J-77.942
    N560X-45.913Y-78.855I-45.913J-77.942
    N561X-45.0Y-77.942I-45.913J-77.942
    N562G01Z-8.0F100
    N563G03X-45.913Y-77.03I-45.913J-77.942F50
    N564X-46.825Y-77.942I-45.913J-77.942
    N565X-45.0Y-79.767I-45.0J-77.942
    N566X-43.175Y-77.942I-45.0J-77.942
    N567X-45.0Y-76.117I-45.0J-77.942
    N568X-46.825Y-77.942I-45.0J-77.942
    N569X-45.913Y-78.855I-45.913J-77.942
    N570X-45.0Y-77.942I-45.913J-77.942
    N571G01Z-10.0F100
    N572G03X-45.913Y-77.03I-45.913J-77.942F50
    N573X-46.825Y-77.942I-45.913J-77.942
    N574X-45.0Y-79.767I-45.0J-77.942
    N575X-43.175Y-77.942I-45.0J-77.942
    N576X-45.0Y-76.117I-45.0J-77.942
    N577X-46.825Y-77.942I-45.0J-77.942
    N578X-45.913Y-78.855I-45.913J-77.942
    N579X-45.0Y-77.942I-45.913J-77.942
    N580G01Z-12.0F100
    N581G03X-45.913Y-77.03I-45.913J-77.942F50
    N582X-46.825Y-77.942I-45.913J-77.942
    N583X-45.0Y-79.767I-45.0J-77.942
    N584X-43.175Y-77.942I-45.0J-77.942
    N585X-45.0Y-76.117I-45.0J-77.942
    N586X-46.825Y-77.942I-45.0J-77.942
    N587X-45.913Y-78.855I-45.913J-77.942
    N588X-45.0Y-77.942I-45.913J-77.942
    N589G01Z-14.0F100
    N590G03X-45.913Y-77.03I-45.913J-77.942F50
    N591X-46.825Y-77.942I-45.913J-77.942
    N592X-45.0Y-79.767I-45.0J-77.942
    N593X-43.175Y-77.942I-45.0J-77.942
    N594X-45.0Y-76.117I-45.0J-77.942
    N595X-46.825Y-77.942I-45.0J-77.942
    N596X-45.913Y-78.855I-45.913J-77.942
    N597X-45.0Y-77.942I-45.913J-77.942
    N598G01Z-16.0F100
    N599G03X-45.913Y-77.03I-45.913J-77.942F50
    N600X-46.825Y-77.942I-45.913J-77.942
    N601X-45.0Y-79.767I-45.0J-77.942
    N602X-43.175Y-77.942I-45.0J-77.942
    N603X-45.0Y-76.117I-45.0J-77.942
    N604X-46.825Y-77.942I-45.0J-77.942
    N605X-45.913Y-78.855I-45.913J-77.942
    N606X-45.0Y-77.942I-45.913J-77.942
    N607G01Z-18.0F100
    N608G03X-45.913Y-77.03I-45.913J-77.942F50
    N609X-46.825Y-77.942I-45.913J-77.942
    N610X-45.0Y-79.767I-45.0J-77.942
    N611X-43.175Y-77.942I-45.0J-77.942
    N612X-45.0Y-76.117I-45.0J-77.942
    N613X-46.825Y-77.942I-45.0J-77.942
    N614X-45.913Y-78.855I-45.913J-77.942
    N615X-45.0Y-77.942I-45.913J-77.942
    N616G01Z-20.0F100
    N617G03X-45.913Y-77.03I-45.913J-77.942F50
    N618X-46.825Y-77.942I-45.913J-77.942
    N619X-45.0Y-79.767I-45.0J-77.942
    N620X-43.175Y-77.942I-45.0J-77.942
    N621X-45.0Y-76.117I-45.0J-77.942
    N622X-46.825Y-77.942I-45.0J-77.942
    N623X-45.913Y-78.855I-45.913J-77.942
    N624X-45.0Y-77.942I-45.913J-77.942
    N625G00Z3.0
    N626Z50.0
    N627X-45.0Y77.942
    N628Z3.0
    N629G01Z-2.0F100
    N630G03X-45.913Y78.855I-45.913J77.942F50
    N631X-46.825Y77.942I-45.913J77.942
    N632X-45.0Y76.117I-45.0J77.942
    N633X-43.175Y77.942I-45.0J77.942
    N634X-45.0Y79.767I-45.0J77.942
    N635X-46.825Y77.942I-45.0J77.942
    N636X-45.913Y77.03I-45.913J77.942
    N637X-45.0Y77.942I-45.913J77.942
    N638G01Z-4.0F100
    N639G03X-45.913Y78.855I-45.913J77.942F50
    N640X-46.825Y77.942I-45.913J77.942
    N641X-45.0Y76.117I-45.0J77.942
    N642X-43.175Y77.942I-45.0J77.942
    N643X-45.0Y79.767I-45.0J77.942
    N644X-46.825Y77.942I-45.0J77.942
    N645X-45.913Y77.03I-45.913J77.942
    N646X-45.0Y77.942I-45.913J77.942
    N647G01Z-6.0F100
    N648G03X-45.913Y78.855I-45.913J77.942F50
    N649X-46.825Y77.942I-45.913J77.942
    N650X-45.0Y76.117I-45.0J77.942
    N651X-43.175Y77.942I-45.0J77.942
    N652X-45.0Y79.767I-45.0J77.942
    N653X-46.825Y77.942I-45.0J77.942
    N654X-45.913Y77.03I-45.913J77.942
    N655X-45.0Y77.942I-45.913J77.942
    N656G01Z-8.0F100
    N657G03X-45.913Y78.855I-45.913J77.942F50
    N658X-46.825Y77.942I-45.913J77.942
    N659X-45.0Y76.117I-45.0J77.942
    N660X-43.175Y77.942I-45.0J77.942
    N661X-45.0Y79.767I-45.0J77.942
    N662X-46.825Y77.942I-45.0J77.942
    N663X-45.913Y77.03I-45.913J77.942
    N664X-45.0Y77.942I-45.913J77.942
    N665G01Z-10.0F100
    N666G03X-45.913Y78.855I-45.913J77.942F50
    N667X-46.825Y77.942I-45.913J77.942
    N668X-45.0Y76.117I-45.0J77.942
    N669X-43.175Y77.942I-45.0J77.942
    N670X-45.0Y79.767I-45.0J77.942
    N671X-46.825Y77.942I-45.0J77.942
    N672X-45.913Y77.03I-45.913J77.942
    N673X-45.0Y77.942I-45.913J77.942
    N674G01Z-12.0F100
    N675G03X-45.913Y78.855I-45.913J77.942F50
    N676X-46.825Y77.942I-45.913J77.942
    N677X-45.0Y76.117I-45.0J77.942
    N678X-43.175Y77.942I-45.0J77.942
    N679X-45.0Y79.767I-45.0J77.942
    N680X-46.825Y77.942I-45.0J77.942
    N681X-45.913Y77.03I-45.913J77.942
    N682X-45.0Y77.942I-45.913J77.942
    N683G01Z-14.0F100
    N684G03X-45.913Y78.855I-45.913J77.942F50
    N685X-46.825Y77.942I-45.913J77.942
    N686X-45.0Y76.117I-45.0J77.942
    N687X-43.175Y77.942I-45.0J77.942
    N688X-45.0Y79.767I-45.0J77.942
    N689X-46.825Y77.942I-45.0J77.942
    N690X-45.913Y77.03I-45.913J77.942
    N691X-45.0Y77.942I-45.913J77.942
    N692G01Z-16.0F100
    N693G03X-45.913Y78.855I-45.913J77.942F50
    N694X-46.825Y77.942I-45.913J77.942
    N695X-45.0Y76.117I-45.0J77.942
    N696X-43.175Y77.942I-45.0J77.942
    N697X-45.0Y79.767I-45.0J77.942
    N698X-46.825Y77.942I-45.0J77.942
    N699X-45.913Y77.03I-45.913J77.942
    N700X-45.0Y77.942I-45.913J77.942
    N701G01Z-18.0F100
    N702G03X-45.913Y78.855I-45.913J77.942F50
    N703X-46.825Y77.942I-45.913J77.942
    N704X-45.0Y76.117I-45.0J77.942
    N705X-43.175Y77.942I-45.0J77.942
    N706X-45.0Y79.767I-45.0J77.942
    N707X-46.825Y77.942I-45.0J77.942
    N708X-45.913Y77.03I-45.913J77.942
    N709X-45.0Y77.942I-45.913J77.942
    N710G01Z-20.0F100
    N711G03X-45.913Y78.855I-45.913J77.942F50
    N712X-46.825Y77.942I-45.913J77.942
    N713X-45.0Y76.117I-45.0J77.942
    N714X-43.175Y77.942I-45.0J77.942
    N715X-45.0Y79.767I-45.0J77.942
    N716X-46.825Y77.942I-45.0J77.942
    N717X-45.913Y77.03I-45.913J77.942
    N718X-45.0Y77.942I-45.913J77.942
    N719G00Z3.0
    N720Z50.0
    N721Z3.0
    N722G01Z-1.75F100
    N723G03X-47.163Y80.105I-47.163J77.942F50
    N724X-49.325Y77.942I-47.163J77.942
    N725X-45.0Y73.617I-45.0J77.942
    N726X-40.675Y77.942I-45.0J77.942
    N727X-45.0Y82.267I-45.0J77.942
    N728X-49.325Y77.942I-45.0J77.942
    N729X-47.163Y75.78I-47.163J77.942
    N730X-45.0Y77.942I-47.163J77.942
    N731G01Z-3.5F100
    N732G03X-47.163Y80.105I-47.163J77.942F50
    N733X-49.325Y77.942I-47.163J77.942
    N734X-45.0Y73.617I-45.0J77.942
    N735X-40.675Y77.942I-45.0J77.942
    N736X-45.0Y82.267I-45.0J77.942
    N737X-49.325Y77.942I-45.0J77.942
    N738X-47.163Y75.78I-47.163J77.942
    N739X-45.0Y77.942I-47.163J77.942
    N740G01Z-5.25F100
    N741G03X-47.163Y80.105I-47.163J77.942F50
    N742X-49.325Y77.942I-47.163J77.942
    N743X-45.0Y73.617I-45.0J77.942
    N744X-40.675Y77.942I-45.0J77.942
    N745X-45.0Y82.267I-45.0J77.942
    N746X-49.325Y77.942I-45.0J77.942
    N747X-47.163Y75.78I-47.163J77.942
    N748X-45.0Y77.942I-47.163J77.942
    N749G01Z-7.0F100
    N750G03X-47.163Y80.105I-47.163J77.942F50
    N751X-49.325Y77.942I-47.163J77.942
    N752X-45.0Y73.617I-45.0J77.942
    N753X-40.675Y77.942I-45.0J77.942
    N754X-45.0Y82.267I-45.0J77.942
    N755X-49.325Y77.942I-45.0J77.942
    N756X-47.163Y75.78I-47.163J77.942
    N757X-45.0Y77.942I-47.163J77.942
    N758G01Z-8.75F100
    N759G03X-47.163Y80.105I-47.163J77.942F50
    N760X-49.325Y77.942I-47.163J77.942
    N761X-45.0Y73.617I-45.0J77.942
    N762X-40.675Y77.942I-45.0J77.942
    N763X-45.0Y82.267I-45.0J77.942
    N764X-49.325Y77.942I-45.0J77.942
    N765X-47.163Y75.78I-47.163J77.942
    N766X-45.0Y77.942I-47.163J77.942
    N767G01Z-10.5F100
    N768G03X-47.163Y80.105I-47.163J77.942F50
    N769X-49.325Y77.942I-47.163J77.942
    N770X-45.0Y73.617I-45.0J77.942
    N771X-40.675Y77.942I-45.0J77.942
    N772X-45.0Y82.267I-45.0J77.942
    N773X-49.325Y77.942I-45.0J77.942
    N774X-47.163Y75.78I-47.163J77.942
    N775X-45.0Y77.942I-47.163J77.942
    N776G00Z3.0
    N777Z50.0
    N778X111.113Y0.0
    N779Z3.0
    N780G01Z-2.0F100
    N781X108.788Y2.325F50
    N782G03X106.463Y3.288I106.463J0.0
    N783X103.175Y0.0I106.463J0.0
    N784G02X0.0Y-103.175I0.0J0.0
    N785X-103.175Y0.0I0.0J0.0
    N786X0.0Y103.175I0.0J0.0
    N787X103.175Y0.0I0.0J0.0
    N788G03X106.463Y-3.288I106.463J0.0
    N789X108.788Y-2.325I106.463J0.0
    N790G01X111.113Y0.0
    N791Z-4.0F100
    N792X108.788Y2.325F50
    N793G03X106.463Y3.288I106.463J0.0
    N794X103.175Y0.0I106.463J0.0
    N795G02X0.0Y-103.175I0.0J0.0
    N796X-103.175Y0.0I0.0J0.0
    N797X0.0Y103.175I0.0J0.0
    N798X103.175Y0.0I0.0J0.0
    N799G03X106.463Y-3.288I106.463J0.0
    N800X108.788Y-2.325I106.463J0.0
    N801G01X111.113Y0.0
    N802Z-6.0F100
    N803X108.788Y2.325F50
    N804G03X106.463Y3.288I106.463J0.0
    N805X103.175Y0.0I106.463J0.0
    N806G02X0.0Y-103.175I0.0J0.0
    N807X-103.175Y0.0I0.0J0.0
    N808X0.0Y103.175I0.0J0.0
    N809X103.175Y0.0I0.0J0.0
    N810G03X106.463Y-3.288I106.463J0.0
    N811X108.788Y-2.325I106.463J0.0
    N812G01X111.113Y0.0
    N813Z-8.0F100
    N814X108.788Y2.325F50
    N815G03X106.463Y3.288I106.463J0.0
    N816X103.175Y0.0I106.463J0.0
    N817G02X0.0Y-103.175I0.0J0.0
    N818X-103.175Y0.0I0.0J0.0
    N819X0.0Y103.175I0.0J0.0
    N820X103.175Y0.0I0.0J0.0
    N821G03X106.463Y-3.288I106.463J0.0
    N822X108.788Y-2.325I106.463J0.0
    N823G01X111.113Y0.0
    N824Z-10.0F100
    N825X108.788Y2.325F50
    N826G03X106.463Y3.288I106.463J0.0
    N827X103.175Y0.0I106.463J0.0
    N828G02X0.0Y-103.175I0.0J0.0
    N829X-103.175Y0.0I0.0J0.0
    N830X0.0Y103.175I0.0J0.0
    N831X103.175Y0.0I0.0J0.0
    N832G03X106.463Y-3.288I106.463J0.0
    N833X108.788Y-2.325I106.463J0.0
    N834G01X111.113Y0.0
    N835Z-12.0F100
    N836X108.788Y2.325F50
    N837G03X106.463Y3.288I106.463J0.0
    N838X103.175Y0.0I106.463J0.0
    N839G02X0.0Y-103.175I0.0J0.0
    N840X-103.175Y0.0I0.0J0.0
    N841X0.0Y103.175I0.0J0.0
    N842X103.175Y0.0I0.0J0.0
    N843G03X106.463Y-3.288I106.463J0.0
    N844X108.788Y-2.325I106.463J0.0
    N845G01X111.113Y0.0
    N846Z-14.0F100
    N847X108.788Y2.325F50
    N848G03X106.463Y3.288I106.463J0.0
    N849X103.175Y0.0I106.463J0.0
    N850G02X0.0Y-103.175I0.0J0.0
    N851X-103.175Y0.0I0.0J0.0
    N852X0.0Y103.175I0.0J0.0
    N853X103.175Y0.0I0.0J0.0
    N854G03X106.463Y-3.288I106.463J0.0
    N855X108.788Y-2.325I106.463J0.0
    N856G01X111.113Y0.0
    N857Z-16.0F100
    N858X108.788Y2.325F50
    N859G03X106.463Y3.288I106.463J0.0
    N860X103.175Y0.0I106.463J0.0
    N861G02X0.0Y-103.175I0.0J0.0
    N862X-103.175Y0.0I0.0J0.0
    N863X0.0Y103.175I0.0J0.0
    N864X103.175Y0.0I0.0J0.0
    N865G03X106.463Y-3.288I106.463J0.0
    N866X108.788Y-2.325I106.463J0.0
    N867G01X111.113Y0.0
    N868Z-18.0F100
    N869X108.788Y2.325F50
    N870G03X106.463Y3.288I106.463J0.0
    N871X103.175Y0.0I106.463J0.0
    N872G02X0.0Y-103.175I0.0J0.0
    N873X-103.175Y0.0I0.0J0.0
    N874X0.0Y103.175I0.0J0.0
    N875X103.175Y0.0I0.0J0.0
    N876G03X106.463Y-3.288I106.463J0.0
    N877X108.788Y-2.325I106.463J0.0
    N878G01X111.113Y0.0
    N879Z-20.0F100
    N880X108.788Y2.325F50
    N881G03X106.463Y3.288I106.463J0.0
    N882X103.175Y0.0I106.463J0.0
    N883G02X0.0Y-103.175I0.0J0.0
    N884X-103.175Y0.0I0.0J0.0
    N885X0.0Y103.175I0.0J0.0
    N886X103.175Y0.0I0.0J0.0
    N887G03X106.463Y-3.288I106.463J0.0
    N888X108.788Y-2.325I106.463J0.0
    N889G01X111.113Y0.0
    N890G00Z50.0
    N891X18.469Y50.743
    N892Z3.0
    N893G01Z-2.0F100
    N894G03X18.457Y50.756I18.457J50.743F50
    N895X18.444Y50.743I18.457J50.743
    N896X18.469Y50.718I18.469J50.743
    N897X18.494Y50.743I18.469J50.743
    N898X18.469Y50.768I18.469J50.743
    N899X18.444Y50.743I18.469J50.743
    N900X18.457Y50.731I18.457J50.743
    N901X18.469Y50.743I18.457J50.743
    N902G01Z-4.0F100
    N903G03X18.457Y50.756I18.457J50.743F50
    N904X18.444Y50.743I18.457J50.743
    N905X18.469Y50.718I18.469J50.743
    N906X18.494Y50.743I18.469J50.743
    N907X18.469Y50.768I18.469J50.743
    N908X18.444Y50.743I18.469J50.743
    N909X18.457Y50.731I18.457J50.743
    N910X18.469Y50.743I18.457J50.743
    N911G01Z-6.0F100
    N912G03X18.457Y50.756I18.457J50.743F50
    N913X18.444Y50.743I18.457J50.743
    N914X18.469Y50.718I18.469J50.743
    N915X18.494Y50.743I18.469J50.743
    N916X18.469Y50.768I18.469J50.743
    N917X18.444Y50.743I18.469J50.743
    N918X18.457Y50.731I18.457J50.743
    N919X18.469Y50.743I18.457J50.743
    N920G01Z-8.0F100
    N921G03X18.457Y50.756I18.457J50.743F50
    N922X18.444Y50.743I18.457J50.743
    N923X18.469Y50.718I18.469J50.743
    N924X18.494Y50.743I18.469J50.743
    N925X18.469Y50.768I18.469J50.743
    N926X18.444Y50.743I18.469J50.743
    N927X18.457Y50.731I18.457J50.743
    N928X18.469Y50.743I18.457J50.743
    N929G01Z-10.0F100
    N930G03X18.457Y50.756I18.457J50.743F50
    N931X18.444Y50.743I18.457J50.743
    N932X18.469Y50.718I18.469J50.743
    N933X18.494Y50.743I18.469J50.743
    N934X18.469Y50.768I18.469J50.743
    N935X18.444Y50.743I18.469J50.743
    N936X18.457Y50.731I18.457J50.743
    N937X18.469Y50.743I18.457J50.743
    N938G01Z-12.0F100
    N939G03X18.457Y50.756I18.457J50.743F50
    N940X18.444Y50.743I18.457J50.743
    N941X18.469Y50.718I18.469J50.743
    N942X18.494Y50.743I18.469J50.743
    N943X18.469Y50.768I18.469J50.743
    N944X18.444Y50.743I18.469J50.743
    N945X18.457Y50.731I18.457J50.743
    N946X18.469Y50.743I18.457J50.743
    N947G01Z-14.0F100
    N948G03X18.457Y50.756I18.457J50.743F50
    N949X18.444Y50.743I18.457J50.743
    N950X18.469Y50.718I18.469J50.743
    N951X18.494Y50.743I18.469J50.743
    N952X18.469Y50.768I18.469J50.743
    N953X18.444Y50.743I18.469J50.743
    N954X18.457Y50.731I18.457J50.743
    N955X18.469Y50.743I18.457J50.743
    N956G01Z-16.0F100
    N957G03X18.457Y50.756I18.457J50.743F50
    N958X18.444Y50.743I18.457J50.743
    N959X18.469Y50.718I18.469J50.743
    N960X18.494Y50.743I18.469J50.743
    N961X18.469Y50.768I18.469J50.743
    N962X18.444Y50.743I18.469J50.743
    N963X18.457Y50.731I18.457J50.743
    N964X18.469Y50.743I18.457J50.743
    N965G01Z-18.0F100
    N966G03X18.457Y50.756I18.457J50.743F50
    N967X18.444Y50.743I18.457J50.743
    N968X18.469Y50.718I18.469J50.743
    N969X18.494Y50.743I18.469J50.743
    N970X18.469Y50.768I18.469J50.743
    N971X18.444Y50.743I18.469J50.743
    N972X18.457Y50.731I18.457J50.743
    N973X18.469Y50.743I18.457J50.743
    N974G01Z-20.0F100
    N975G03X18.457Y50.756I18.457J50.743F50
    N976X18.444Y50.743I18.457J50.743
    N977X18.469Y50.718I18.469J50.743
    N978X18.494Y50.743I18.469J50.743
    N979X18.469Y50.768I18.469J50.743
    N980X18.444Y50.743I18.469J50.743
    N981X18.457Y50.731I18.457J50.743
    N982X18.469Y50.743I18.457J50.743
    N983G00Z3.0
    N984Z50.0
    N985X34.711Y-41.366
    N986Z3.0
    N987G01Z-2.0F100
    N988G03X34.698Y-41.354I34.698J-41.366F50
    N989X34.686Y-41.366I34.698J-41.366
    N990X34.711Y-41.391I34.711J-41.366
    N991X34.736Y-41.366I34.711J-41.366
    N992X34.711Y-41.341I34.711J-41.366
    N993X34.686Y-41.366I34.711J-41.366
    N994X34.698Y-41.379I34.698J-41.366
    N995X34.711Y-41.366I34.698J-41.366
    N996G01Z-4.0F100
    N997G03X34.698Y-41.354I34.698J-41.366F50
    N998X34.686Y-41.366I34.698J-41.366
    N999X34.711Y-41.391I34.711J-41.366
    N1000X34.736Y-41.366I34.711J-41.366
    N1001X34.711Y-41.341I34.711J-41.366
    N1002X34.686Y-41.366I34.711J-41.366
    N1003X34.698Y-41.379I34.698J-41.366
    N1004X34.711Y-41.366I34.698J-41.366
    N1005G01Z-6.0F100
    N1006G03X34.698Y-41.354I34.698J-41.366F50
    N1007X34.686Y-41.366I34.698J-41.366
    N1008X34.711Y-41.391I34.711J-41.366
    N1009X34.736Y-41.366I34.711J-41.366
    N1010X34.711Y-41.341I34.711J-41.366
    N1011X34.686Y-41.366I34.711J-41.366
    N1012X34.698Y-41.379I34.698J-41.366
    N1013X34.711Y-41.366I34.698J-41.366
    N1014G01Z-8.0F100
    N1015G03X34.698Y-41.354I34.698J-41.366F50
    N1016X34.686Y-41.366I34.698J-41.366
    N1017X34.711Y-41.391I34.711J-41.366
    N1018X34.736Y-41.366I34.711J-41.366
    N1019X34.711Y-41.341I34.711J-41.366
    N1020X34.686Y-41.366I34.711J-41.366
    N1021X34.698Y-41.379I34.698J-41.366
    N1022X34.711Y-41.366I34.698J-41.366
    N1023G01Z-10.0F100
    N1024G03X34.698Y-41.354I34.698J-41.366F50
    N1025X34.686Y-41.366I34.698J-41.366
    N1026X34.711Y-41.391I34.711J-41.366
    N1027X34.736Y-41.366I34.711J-41.366
    N1028X34.711Y-41.341I34.711J-41.366
    N1029X34.686Y-41.366I34.711J-41.366
    N1030X34.698Y-41.379I34.698J-41.366
    N1031X34.711Y-41.366I34.698J-41.366
    N1032G01Z-12.0F100
    N1033G03X34.698Y-41.354I34.698J-41.366F50
    N1034X34.686Y-41.366I34.698J-41.366
    N1035X34.711Y-41.391I34.711J-41.366
    N1036X34.736Y-41.366I34.711J-41.366
    N1037X34.711Y-41.341I34.711J-41.366
    N1038X34.686Y-41.366I34.711J-41.366
    N1039X34.698Y-41.379I34.698J-41.366
    N1040X34.711Y-41.366I34.698J-41.366
    N1041G01Z-14.0F100
    N1042G03X34.698Y-41.354I34.698J-41.366F50
    N1043X34.686Y-41.366I34.698J-41.366
    N1044X34.711Y-41.391I34.711J-41.366
    N1045X34.736Y-41.366I34.711J-41.366
    N1046X34.711Y-41.341I34.711J-41.366
    N1047X34.686Y-41.366I34.711J-41.366
    N1048X34.698Y-41.379I34.698J-41.366
    N1049X34.711Y-41.366I34.698J-41.366
    N1050G01Z-16.0F100
    N1051G03X34.698Y-41.354I34.698J-41.366F50
    N1052X34.686Y-41.366I34.698J-41.366
    N1053X34.711Y-41.391I34.711J-41.366
    N1054X34.736Y-41.366I34.711J-41.366
    N1055X34.711Y-41.341I34.711J-41.366
    N1056X34.686Y-41.366I34.711J-41.366
    N1057X34.698Y-41.379I34.698J-41.366
    N1058X34.711Y-41.366I34.698J-41.366
    N1059G01Z-18.0F100
    N1060G03X34.698Y-41.354I34.698J-41.366F50
    N1061X34.686Y-41.366I34.698J-41.366
    N1062X34.711Y-41.391I34.711J-41.366
    N1063X34.736Y-41.366I34.711J-41.366
    N1064X34.711Y-41.341I34.711J-41.366
    N1065X34.686Y-41.366I34.711J-41.366
    N1066X34.698Y-41.379I34.698J-41.366
    N1067X34.711Y-41.366I34.698J-41.366
    N1068G01Z-20.0F100
    N1069G03X34.698Y-41.354I34.698J-41.366F50
    N1070X34.686Y-41.366I34.698J-41.366
    N1071X34.711Y-41.391I34.711J-41.366
    N1072X34.736Y-41.366I34.711J-41.366
    N1073X34.711Y-41.341I34.711J-41.366
    N1074X34.686Y-41.366I34.711J-41.366
    N1075X34.698Y-41.379I34.698J-41.366
    N1076X34.711Y-41.366I34.698J-41.366
    N1077G00Z3.0
    N1078Z50.0
    N1079X-53.18Y-9.377
    N1080Z3.0
    N1081G01Z-2.0F100
    N1082G03X-53.192Y-9.365I-53.192J-9.377F50
    N1083X-53.205Y-9.377I-53.192J-9.377
    N1084X-53.18Y-9.402I-53.18J-9.377
    N1085X-53.155Y-9.377I-53.18J-9.377
    N1086X-53.18Y-9.352I-53.18J-9.377
    N1087X-53.205Y-9.377I-53.18J-9.377
    N1088X-53.192Y-9.39I-53.192J-9.377
    N1089X-53.18Y-9.377I-53.192J-9.377
    N1090G01Z-4.0F100
    N1091G03X-53.192Y-9.365I-53.192J-9.377F50
    N1092X-53.205Y-9.377I-53.192J-9.377
    N1093X-53.18Y-9.402I-53.18J-9.377
    N1094X-53.155Y-9.377I-53.18J-9.377
    N1095X-53.18Y-9.352I-53.18J-9.377
    N1096X-53.205Y-9.377I-53.18J-9.377
    N1097X-53.192Y-9.39I-53.192J-9.377
    N1098X-53.18Y-9.377I-53.192J-9.377
    N1099G01Z-6.0F100
    N1100G03X-53.192Y-9.365I-53.192J-9.377F50
    N1101X-53.205Y-9.377I-53.192J-9.377
    N1102X-53.18Y-9.402I-53.18J-9.377
    N1103X-53.155Y-9.377I-53.18J-9.377
    N1104X-53.18Y-9.352I-53.18J-9.377
    N1105X-53.205Y-9.377I-53.18J-9.377
    N1106X-53.192Y-9.39I-53.192J-9.377
    N1107X-53.18Y-9.377I-53.192J-9.377
    N1108G01Z-8.0F100
    N1109G03X-53.192Y-9.365I-53.192J-9.377F50
    N1110X-53.205Y-9.377I-53.192J-9.377
    N1111X-53.18Y-9.402I-53.18J-9.377
    N1112X-53.155Y-9.377I-53.18J-9.377
    N1113X-53.18Y-9.352I-53.18J-9.377
    N1114X-53.205Y-9.377I-53.18J-9.377
    N1115X-53.192Y-9.39I-53.192J-9.377
    N1116X-53.18Y-9.377I-53.192J-9.377
    N1117G01Z-10.0F100
    N1118G03X-53.192Y-9.365I-53.192J-9.377F50
    N1119X-53.205Y-9.377I-53.192J-9.377
    N1120X-53.18Y-9.402I-53.18J-9.377
    N1121X-53.155Y-9.377I-53.18J-9.377
    N1122X-53.18Y-9.352I-53.18J-9.377
    N1123X-53.205Y-9.377I-53.18J-9.377
    N1124X-53.192Y-9.39I-53.192J-9.377
    N1125X-53.18Y-9.377I-53.192J-9.377
    N1126G01Z-12.0F100
    N1127G03X-53.192Y-9.365I-53.192J-9.377F50
    N1128X-53.205Y-9.377I-53.192J-9.377
    N1129X-53.18Y-9.402I-53.18J-9.377
    N1130X-53.155Y-9.377I-53.18J-9.377
    N1131X-53.18Y-9.352I-53.18J-9.377
    N1132X-53.205Y-9.377I-53.18J-9.377
    N1133X-53.192Y-9.39I-53.192J-9.377
    N1134X-53.18Y-9.377I-53.192J-9.377
    N1135G01Z-14.0F100
    N1136G03X-53.192Y-9.365I-53.192J-9.377F50
    N1137X-53.205Y-9.377I-53.192J-9.377
    N1138X-53.18Y-9.402I-53.18J-9.377
    N1139X-53.155Y-9.377I-53.18J-9.377
    N1140X-53.18Y-9.352I-53.18J-9.377
    N1141X-53.205Y-9.377I-53.18J-9.377
    N1142X-53.192Y-9.39I-53.192J-9.377
    N1143X-53.18Y-9.377I-53.192J-9.377
    N1144G01Z-16.0F100
    N1145G03X-53.192Y-9.365I-53.192J-9.377F50
    N1146X-53.205Y-9.377I-53.192J-9.377
    N1147X-53.18Y-9.402I-53.18J-9.377
    N1148X-53.155Y-9.377I-53.18J-9.377
    N1149X-53.18Y-9.352I-53.18J-9.377
    N1150X-53.205Y-9.377I-53.18J-9.377
    N1151X-53.192Y-9.39I-53.192J-9.377
    N1152X-53.18Y-9.377I-53.192J-9.377
    N1153G01Z-18.0F100
    N1154G03X-53.192Y-9.365I-53.192J-9.377F50
    N1155X-53.205Y-9.377I-53.192J-9.377
    N1156X-53.18Y-9.402I-53.18J-9.377
    N1157X-53.155Y-9.377I-53.18J-9.377
    N1158X-53.18Y-9.352I-53.18J-9.377
    N1159X-53.205Y-9.377I-53.18J-9.377
    N1160X-53.192Y-9.39I-53.192J-9.377
    N1161X-53.18Y-9.377I-53.192J-9.377
    N1162G01Z-20.0F100
    N1163G03X-53.192Y-9.365I-53.192J-9.377F50
    N1164X-53.205Y-9.377I-53.192J-9.377
    N1165X-53.18Y-9.402I-53.18J-9.377
    N1166X-53.155Y-9.377I-53.18J-9.377
    N1167X-53.18Y-9.352I-53.18J-9.377
    N1168X-53.205Y-9.377I-53.18J-9.377
    N1169X-53.192Y-9.39I-53.192J-9.377
    N1170X-53.18Y-9.377I-53.192J-9.377
    N1171G00Z3.0
    N1172Z50.0
    N1173M09
    N1174M30
    it is all circles. it is a backing plate for my lathe. The machine is anIH cnc with mach 3 software. The design was done in dolphincad/cam. it errors out at line 12. Thanks
    May 2007
    781
    First off when posting a lot of code push the "#" button in the second line of the message editor and put the code inside the code tags.
    That way your message is not hell and gone long.
    Second lines 15 and 16 have I and J values of 0.0 that means a radius of zero.
    I am thinking your CAM program and or post processor need some adjustment.
    Code:
    Mar 2007
    62
    thanks for the tip on the short code.. I am not very familiar with the actual coding of things so I did not notice that. I have made another drawing and it has done the same thing. Where do I look for the adjustments on the cam or processor? Thanks
    Jun 2005
    1015
    change your code output so your I and J values are not used and when programming a G02 and G03 you use an R value.
    Mar 2007
    62
    Runner, thanks for the input but I have no idea as to where i change these. Can you shed some more light on this for me? Thanks
    Jun 2005
    1015
    this is in your post processor and not in mach 3. usually there are settings in the post processor on how to output code. one of the options should be R instead of I and J. use the R option and you won't have any more issues.
    Mar 2007
    62
    I am using Dolphin Cad Cam are u familiar with this software? I can not find anywhere to change the output code. when I do my post process there is just a button at the bottom that I hit. If you can shed anymore light i would appreciate it. Thanks again
    Jun 2005
    1015
    I am not familiar with dolphin cad/cam. i bought and use onecnc xr3.
    Mar 2007
    62
    do you have a link to the software? i am not happy with the dolphin software, never have been. The support sucks. when i had some issues awhile back with the post processor it was like pulling teeth to get them to respond. i finally figured out that they sent me the wrong processor and evr since then my phone calls and emails have gone unanswered. is the service better with the one you have? Thanks
    Jun 2005
    1015
    http://www.onecnc.net/
    they also have a forum on cnczone and they have their own online help forum. and yes their tech support is fantastic.
    Mar 2007
    62
    Thanks i will look into it.
    Dec 2007
    496
    Been using dolphin partmaster for a little over 2 years now and have gotten help about 99.9% of the time (maybe once on a Sunday it took a bit longer). Not to take anything away from Onecnc as it is probably a very nice product, but maybe SWC should check himself in the mirror and realize that YOU may be the problem and not the software. Just went through about the last 50 threads and didnt really see anyone having problems.
    Dec 2007
    496
    Oh yea, just my .02 cents
    Mar 2007
    62
    Harley, thanks for your insight. I did contact Dolphin again today and they were very helpful this time. Using what I learned here from runner and others I explained the issue to them,they sent me the right post processor this time. problem is nor fixed. Thanks
    Dec 2007
    496
    Very good to hear. This forum has helped me numerous times over the years in all phases. Communicating with other users is such a help when it comes to certain issues. Glad everything is working well for you now.
  1. Mazatrol Program into a G Code Program
    By fuzzman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 04:27 PM
  2. Corrupt program issues
    By patnok in forum Haas Lathes
    Last Post: 10-10-2009, 03:05 AM
  3. Loading program issues
    By jaylsworth in forum Fadal
    Last Post: 03-18-2009, 01:56 PM
  4. Program restart issues HTC400 M-Plus
    By MJMark in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-16-2008, 04:36 PM
  5. Replies: 11
    Last Post: 10-09-2005, 05:45 AM
