603,413 active members*
2,449 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > Low cost tooling for die sinking?
    Nov 2009
    18
    I'm start-up with an idea for low-volume plastic injection molding.
    Keeping costs down, I'll need to do my own die sinking.
    I have a CAD/CAM/small CNC mill setup, but with a spindle speed of 4,500rpm max I'm pretty sure I'll get nowhere using 1mm ball-end cutters on a detailed little injection mold, right?
    So if CNC EDM is still $50,000 plus, and a High speed mill is getting up there too, what do I do? Get an old 3d pantograph? Or any other suggestions how to do it?
    Feb 2010
    Right now is the best time to buy used machinery. I've seen used cnc agies on the web for around $10,000. If your gonna do injection molding you definately need a sinker. I'm still gettin by with my old excello 20 amp doesnt even have a readout on it. Have to depth mike to the edge of the the trode to locate. Ive worked in high end mold shops and run makino cnc sinkers nut that old excello is almost just as fast. Only drawback is you gotta run flush and not as accurate as far as overburn.
    I suggest that you are only making a reply to an old dead post to spam advertise your company by plastering your post with links to your website.
    This is not a pertinent post!
    Robert
    3D Accuracy
  1. How much does MC cost???
    By SDK73 in forum Mastercam
    Last Post: 08-24-2009, 02:57 AM
  2. Cost of tooling
    By gmmco in forum Uncategorised MetalWorking Machines
    Last Post: 09-29-2008, 01:50 AM
  3. Cost of tooling.
    By l u k e in forum MetalWork Discussion
    Last Post: 07-24-2006, 02:16 PM
  4. How much does it cost?
    By CnC_BoY in forum Bridgeport / Hardinge Mills
    Last Post: 04-13-2006, 09:30 PM
  5. Replies: 5
    Last Post: 05-29-2005, 03:17 AM
