603,853 active members*
4,341 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Servo Motor Overheating with Geckodrive 320
    Mar 2009
    16
    Hi everybody,
    For my future cnc 5'x 5' I use 4 axes drives, 3 Gecko G320 and 1 G320X. The
    Power Supply is from Kelling 7220 this means 72V and 4x 5A.
    The motors are 3 Parvex RS440RG(90VDC ,7A, 3000RPM) and 1 motor from Keling
    KL34-180-90 (90VDC, 7.8A, 3200RPM). The Encoders are from Digi-Key(AMT102-V with
    500 line).I use Mach 3. Everything is new.
    Now the problem is when I run just the motors without to be connected to the
    ballscrew, motor from Kelling stay cool, but another 3 motors(parvex) after
    20-30 min are overheating. I tried to switch the motor and the problem stay the
    same. This is my first cnc and I don't know to much. Maybe I need to connect
    some resistor to the motor?
    If somebody can help me I will be very thankful.
    Help please.
    www.parvex.com/fichesmot/english/rs/rs440g.pdf
    www.kelinginc.net/KL34-180-90.pdf
    Mar 2009
    16
    Last Night I play with my motor the velociti and acceleration, I try to ajust
    the PID, Gain, Limit everything an the problem it si the same. I open one Parker
    motor to look inside. Inside it is one rotor and 4 magnets nothing more(the
    motor is with 4 brush). I don't have the osceloscop but I think will be the
    same. Iven whe they stay in IDL thes stil go to hot. Do you think is some way to
    fix this problem or I need to spend another 500$ to buy 3 motor from Keling and
    fix the problem. The motor from the Kelling stay cool all the time doesn't
    meater if hi run or stai IDL.
    Maybe I need to buy some inductor but I don't know what tipe.
    It's very confusing situation. The Brand Parvex or Parker is big brand, but they
    don't work for me.
    Thank you.
  1. X4+ Overheating
    By Des Jacobsen in forum Syil Products
    Last Post: 01-14-2009, 06:58 PM
  2. 1988 fadal A axis motor overheating
    By smts in forum Fadal
    Last Post: 12-29-2008, 04:56 PM
  3. Sell Servo Motor, Servo Drive by GSKcnc.com from China
    By salecnc@hotmail in forum News Announcements
    Last Post: 06-03-2008, 08:55 PM
  4. Replies: 0
    Last Post: 02-08-2008, 02:04 AM
  5. Y Servo Overheating
    By screensnot in forum Fadal
    Last Post: 02-10-2006, 02:40 AM
