587,420 active members*
3,315 visitors online*
    Dec 2009
    5
    EMCO F1P-CNC Tool Holder
    Hello, i work for a surplus reseller, and we have recently acquired an EMCO F1P-CNC machine with EMCOtronic M1 controller.
    So far, we have gotten excellent responses from the controller unit. Unfortunately, we did not receive the tapered-collet tool chuck which should have come with this unit. Without this chuck installed, the controller returns "Alarm 90, collet/chuck not ready" and refuses to move any of the control motors.
    We would very much like to buy a cheap collet we can install for testing this unit, but we have no idea what size we need to buy. The manual is utterly unhelpful (is shows an exploded diagram of the tool holder, but no size indications), and EMCO-Maier USA doesn't seem to care to answer their phone.
    So what size tapered collet chuck do we need to order for this thing? The only thing i have been able to find about the thing is that the wide end of the taper is 1-1/4" and that the taper well is 2" deep. The diagram in the manual also shows a small ball protrusion on top of the taper for retention.
    Does anyone know what we need to buy to have a tool holder for this thing?
    Dec 2009
    5
    bump
    Aug 2012
    8
    Re: EMCO F1P-CNC Tool Holder
    Actually, I have found out the precise name of this collet type from the manuals, so I know it is in there. Unfortunately the manuals are in scanned PDF format only and searching them is impossible, and I have since forgotten the specifics. The collet you want is a proprietary one that was, according to the manual, similar to /compatible with a DIN standard one (my memory fails me at this point). At first I was hesitant to post this, but I realized that if I were in your shoes, I would have liked to know that the information IS available in the manual.
  1. Vertical lathe tool holder for Tormach Tool System.
    By TXFred in forum News Announcements
    Last Post: 08-18-2014, 09:20 AM
  2. Replies: 10
    Last Post: 11-06-2012, 11:43 PM
  3. emco compact 5 - lathe tool holder series??
    By NoviceLatheMan in forum EMCO Lathe
    Last Post: 01-27-2011, 06:33 PM
  4. emco 5 CNC tool holder problem
    By sparkymike in forum EMCO Lathe
    Last Post: 05-06-2010, 07:23 PM
  5. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 11:04 AM
