586,106 active members*
3,027 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Building PicSteps - Trying to find missing specs for the BOB
    Nov 2009
    4
    Question Building PicSteps - Trying to find missing specs for the BOB
    Hi all,
    I've started building my PicSteps, including the Break-out Board and the input daughter board. Some pics attached for people wo like pictures
    Just one question: for those who have already built the BOB, what values are the TBA resistors ?
    regards,
    Raf
    Attached Thumbnails Attached Thumbnails IMGP2707b.JPG   IMGP2709b.jpg   IMGP2712b.jpg   IMGP2726b.jpg
    Feb 2005
    521
    Hi Raf,
    I think I used 470R.
    There is a bit more info and trouble shooting around this post...
    http://www.cnczone.com/forums/showth...-bob#post76429
    ...jeez where'd those last 4 years go ?!?!
    Good luck!
    www.cambam.co.uk
    Nov 2009
    4
    Smile Progress...
    10bulls,
    Thanks for the link to that thread, it really got me up to speed!
    Some photos with the progress i've made building the
    controllers and picsteps =)
    Does anyone know the value for C1 on the input board ? 1uF ?
    Raf
    Nov 2009
    4
    Almost there!
    Much much later I almost have a working setup.
    After fiddling with the acceleration values in Mach3 and setting the stepping mode jumper to full step i managed to blow an LMD, and yes, that was with a proper heatsink attached (not shown in the photos), and the voltage set to 38V.
    I got it replaced and it's working again
    The only problem i have now is when I quickly switch directions while jogging,
    then it doesn't always change direction.. The indicator LEDs however clearly show the DIR signal changing and all my picsteps behave the same.
    Does anyone have an idea why it does this ?
    I'm using the 20Mhz firmware without current reduction.
    Perhaps changing the opto resistors (now at 420R) to a lower value will yield a direction pulse that is a little longer ?
    Some pics attached.
    Attached Thumbnails Attached Thumbnails IMGP2807.jpg   IMGP2803.jpg   IMGP2801.jpg
    Jan 2009
    57
    Pulse width
    Quote Originally Posted by scrat View Post
    Some pics attached.
    Mach3 allows you to set the pulse widths in the configuration. Give that a try first. P.S. Uncluttered work area envy.
  1. Missing specs. on parts.
    By kimfmx in forum Linear and Rotary Motion
    Last Post: 03-16-2008, 05:01 PM
  2. Fault in 1 of 3 PICSteps... Suggestions ?
    By Agro in forum CNC Machine Related Electronics
    Last Post: 05-18-2006, 10:36 AM
  3. Replies: 4
    Last Post: 02-04-2006, 11:19 PM
  4. where to find specs for vexta motors
    By DanOSB in forum Stepper Motors / Drives
    Last Post: 09-14-2005, 03:17 AM
  5. Where can I find Detail Specs Servo & Drive MEans ?
    By Calico in forum Servo Motors / Drives
    Last Post: 02-28-2005, 06:37 PM
