586,100 active members*
2,713 visitors online*
    Feb 2009
    Pinch Turning in PartMarker
    Hey there, I am hoping someone has already tried or has successfully done this before.
    I am trying to program a pinch turning path in Partmaker. My problem is that I will need to use a boring bar in an end working station to follow my gang turning tool. Has anyone tried to do this and if so is it possible to program this in PartMaker? What steps would I need to complete to make this happen?
    Any help anyone can give is appreciated
    Thanks!
    Dec 2008
    54
    Pinch Turn w/ end working
    Hi Pac,
    Sounds like you have a Cit L or Star SR machine. Those generally allow for M2 mode with the End Working normally being a Drilling style process. This is the way you would need to set something like this up. If your on maintenance we would be happy to help out with any posting issues, but that may give you a start.
    Bill
    Bill Cain
    www.partmaker.com
    Feb 2009
    Sorry, Yes we are using a Citizen L32.
    If I where to check the pinch turning box in the Profile Group Parameters window how does Partmaker know where or what location the second tool is? Is there a way to tell it which tool location the second tool is at?
    Dec 2008
    54
    For the CitL there is no "Pinch Turning". You will create 2 processes in PartMaker and at the Process table you would use the "M2S0" mode without checking the pinch turning check box.
    Quote Originally Posted by PACMan1779 View Post
    Bill Cain
    www.partmaker.com
  1. Pinch (Balance) Turning?
    By sidswiss in forum CNC Swiss Screw Machines
    Last Post: 10-18-2021, 12:29 AM
  2. Please enlighten me on pinch turning in a ZL-203
    By Letter Buck in forum Mori Seiki lathes
    Last Post: 08-21-2011, 10:00 PM
  3. Please enlighten me on pinch turning...
    By Letter Buck in forum G-Code Programing
    Last Post: 05-16-2008, 07:43 PM
  4. Stop Buying Expensive EDM Pinch Rollers
    By Jim Abbett in forum News Announcements
    Last Post: 09-29-2004, 09:51 PM
