588,451 active members*
6,107 visitors online*
    Oct 2006
    85
    turning a 1/8 npt on a lathe
    Can someone give me a sample program for a male 1/8 npt?
    I've got a faunc oi-tb control.
    1st time is always the hardest!
    Thanks in advance for your help
    Best,
    Steve
    Feb 2006
    992
    Not sure what lathe you have, but I will ahead anyway. Program for single point threat cutter. It's only an sample it's come off of my head, I had been so long the last time I did NPT now I forgot the what is the angle for it and what is the minor diameter and what is major diameter ....... so check Machinist Handbook and adjust accordingly OK.
    G00 X.65.Z.1 M3
    G92X.62Z-.6I.12 (I is the angle of the tape)
    X.61
    X.6
    x59
    G0Z.1
    The best way to learn is trial error.
    May 2007
    1003
    Finish turn 1/64R
    G1X.2777Z0F.003
    G3X.3074Z-.0061R.021
    G1X.3953Z-.0501
    X.405Z-.2066
    Z-?
    Finish turn 1/32R
    G1X.2477Z0F.003
    G3X.2987Z-.0105R.036
    G1X.3949Z-.0586
    X.405Z-.2214
    Z-?
    G76 2-block
    X.44Z.3
    G76P000155Q30R.001
    G76X.361Z-.5P296Q100R-.0249F.03704
    G76 1-block
    X.44Z.3
    G76X.361Z-.5I-.0249K.0296D100F.03704A55P?
    P is an option (as is I) which determines how the thread is cut. Choices are 1 through 4.
    P1= one-side cutting with constant cutting amount
    P2= zigzag cutting with constant cutting amount
    P3= one-side cutting with constant cutting depth
    P4= zigzag cutting with constant cutting depth
    P1 is default.
    Or you can use G32 which is the most powerful threading cycle, but requires a lot more on your part to program. Unlike the G92 cycle, you can program any kind of compound infeed you desire. With the G32 you could program a 1/8NPT on the front, change the G32 block to cut a straight thread (at any pitch) and change directions at the end of that for another type of thread if need be.
  1. lathe turning
    By klugster in forum MetalWork Discussion
    Last Post: 11-01-2012, 05:25 AM
  2. Lathe turning finish help
    By Ira in forum Shopmaster/Shoptask
    Last Post: 10-28-2009, 06:26 PM
  3. On Turning On A Lathe
    By Brenck in forum CNC Machine Related Electronics
    Last Post: 09-29-2009, 07:41 AM
  4. Best CAM Software for turning / lathe?
    By trivisingh in forum Uncategorised CAM Discussion
    Last Post: 07-01-2008, 03:34 AM
  5. CNC Vertical Turning Lathe
    By Harshwardhan in forum Uncategorised MetalWorking Machines
    Last Post: 10-11-2007, 05:58 PM
