586,036 active members*
3,819 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Build Inexpensive CNC with decent tolerances-Share your input
Page 1 of 2 12
Results 1 to 20 of 24
    Dec 2009
    24
    Hello! A few thoughts on starting out cheaply. This is oriented towards a small machine maybe 12x12 inches to 24x24 inchess x-y and maybe 6-8 inches z coordinate with the ability to mill Aluminum .
    First you need a CAD program..I highly reccomend TurboCad Deluxe. Turbocad has been around since 1985 and has had tons of development time put into it. TurboCad 12,14,15, and 16 all run on Vista and Windows 7 in both 32 and 64 bit OS version. Turbocad uses the same ASCIS engine that autocad does, and accepts every cad format. Does 95-97% of what Autocad does..actually it just does not have command line entry ..which you really dont need anyways.. Cost is $25 or less on amazon.com for deluxe14 with a tutorial (and it does 3d!)..Pro TurboCad is better but costs money..TurboCad is very similar to autocad...CAD has an immense learning curve..Cadcourse.com has a free 2d drawing tutorial and a really great training bundle for $65..you need the tutorials. No I dont work for turbocad...its just a great program for the money..Google had turbocad write sketchup for them buy the way..(dont use sketchup..get turbocad instead)
    As far a linear motion..stay away from ballscrews..they are great but simply cost way way too much..Go with 1/2 inch 10 thread per inch right hand turn ,single start ACME threaded rod. Mcmaster.com sells it for $7 for a 3 foot long piece and $12 for a six foot long piece..shipping is about 5-6 bucks..cant go wong..I would not use regular threaded rod from a hardware store or better grad ACME right now as you just want to get going and its going to be accurate to .0010 to .001 inch . Two start ACME and precision ACME cost a lot more..General acme will get the job done.
    As far a stepper motors go..you dont want to go too big or too small..the smallest I would go is 166 oz/in...127 oz/in wold be sort of ok..the largest..260 oz in..If you get too big of a stepper (..500 oz ect..) then you have a 15 amp fusebreaker in your shop then you will have wiring hazards and possible fuse tripping You can ge 166 oz/in 24 volt 3 amp bipolar Minebea/Astrosyn Hybrid bipolar motor for $12 ea at mpja.com..these are really great motors..remember..the ACME screw holds the gantry in position..the motor just moves it there..(there is also what is called detent torque from the motor..but you dont need a whole lot.)Go bipolar..they are stronger..the old motors are round..new motors are square....you also should have a dedicated computer there to run the CAM software that takes the CAD model and converts it to machine code or "G Code". Any old garage sale computer would work..Load Ubuntu on it .(free Linux) So you also need a second pice of software CAM.CAM takes the CAD model and translates it into "G code " for the cnc machine to read....LinuxCNC.org has ECM for free..its pretty good..in fact Shaerline uses it on their small mills. And its fully documented..Again there is better suff out there but this program would work just fine! As far as controllers for the steppers go..look around..you absolutly must have documentation and operating software for the controller..dont buy a controller without directions! Stay away from expensive controllers for now..ie.. Lizard brand..they are truly great but simply cost too much ! Buy them later when you have more money.
    You will need a general electronics book..the best on the market is wirttern by Floyd..Electronics-Electron Flow..$3 for a used copy from amazon..any edition from 1997 onward is just fine..Well illustrated expensive book new though..You also will need a book on Stepper motors and one on Industrial Electonics..again ..used..amazon.com..1997 or later..new costs too much.
    Power supply..24 volt 12 amp from Marlin Jones $25..mpja.com..they also sell the Minebea 166 oz/in 3 amp 24 volt motors for $12 ea...not the biggest..but they will get the job done..especially for you since you dont have a giant x-y table to worry about and by the way..the reason people here talk about rapid movement is that moving too slow burns wood and many people here are in a production enviroment..the 166 and single start acme will work just fine in your situation...also some people here are using $250,000 machines! or more$ ! .... Or are on a fast production line..so what applies to them does not apply to you!
    As far as a spindle goes either use a porter-cable router or much much better get a real spingle intended for aluminum/ and or precison work..about $95 if you look..read the tolerances..
    The ACME general from Mcmaster is Keystone brand and its very high quality for general acme threaded rod...Yes two start might be better..but it costs a lot more..plus its only available in precision grade..ie.. .00001 tolerance..if you can afford the precison two start ACME go for....but get 1/2 inch!.. (smaller diameter flexes or "whips" at high rpm..)
    You can build a machine cheaply that will get you .0010 to .001 ....any more precison costs a lot more.. As does the size of the machine..bigger machines cost more..just build it yourself..have a local machine shop cut and drill for you then assembl;e it yourself..Slotslva has a $25 set of plans or design it yourself..Browse the web for cnc builds.I would reccomend a combination of Aluminum and Steel..probably steel for the spindle mount as it absorbs vibration better than Aluminum..Moving parts..Aluminum..Use rubber vibration dampers here and there..As for Linear slides..certain drawer slides have good tolerances..about .001 with a 200 lb weight limit..24 inch travel..cost $25 at home depot.read the specs atthe mfg site first or look at them....PMinMO.com is a great great resource!!..To get .001 you would need the real for cnc router $95 spindle..and have it mounted correctly..Porter cable is good..but your have to buy the entire roiuter to get the spindle..Avoid general hardware stuff in critical places..use it elesewhere for bolting things together..Make sure you get the wiring right ..otherwise it creates a fire hazard!! Also I would enclose it .(use plexiglas on one side so you can see whats going on.three or more different materials snadwiched toigether yeild the best sound insulation.(good safety too..from flying broken bits..shards ect..).put a usb webcam camera with a range extender in with the machine so you can watch it and listen remotely in your living room! Put a fire alarm in with the machine..again you might not be with the machine when its running!..Put the electronics in an old computer case with a fan..Make sure the stepper controllers have the amp capacity for your steppers and the voltage you want..buy a stepper motor with a higher voltage to start with same with amps..they dont really cost much more anyways and its safer to run a 24 voilt motor with a 24 volt power supply anyways..in other words dont put 52 volts on a 3 volt motor for an extended period of time unattended..24 volts is plenty for a small system..and rig up a spray cooling set up for coolant/lubricant..along with a fan to help cool...Most of the items you need will have to come from the internet..You can use drawer slides as linear slides.. from Homedepot or Lowes ect..go look..or read the specs..some have tolerances to .001 in..24 inch long slides with 200 lb capacity cost about $20..I can not remeber which ones had the .001 spec but its on the drawer mfg website..
    If you are going to build a machine with x-y coordinates longer than 36 inches go with 5/8 inch ACME..over 4 foot x-y ..go with one inch ACME..bigger tables require a little bit bigger motors..any thing over 4 foot go with 300 oz/inch to 500 oz/in motors..On the longer length tables you would want two pillow block bearing supports on each end about 1 1/2 to 2 inches apart to help prevent whipping..also you can counterbalace the machine from above with a "slinky" type spring mounter above the moving gantry..Some types of wood dust are toxic..if you work with wood you need to know which woods!! And also could explode under certain circumstances..use a brass rod to drive a sparkless fan (mount the fan motor outside of the cnc enclosure.keep the dust out..You can make a vacuum pump out of an old refrigerator compressor if you read about it online! ..And again..soundproof it with walls made of 3 different materials..plywood..rubber..drywall..with a plexiglass window..use a cheap $75 air conditioner for the enclosure if heat becomes a problem..but again think about your fusebox in your house..dont overload the fusebox.if the steppers become hot..attach computer cpu heat sinks to them.or finned copper....again..you should watch overvoltaging the motors in an unmonitored situation due to hazards...but make sure its got heat sinks on all 4 sides so you dont get a cool spot. Buy 24 -48volt motors to begin with (if you can get a good price)..dont put 48 volts on a one volt motor..yes you can get away with it..but..?(thats just my opinion) ! Read the specs before you buy anything to make sure it is compatible with what you have..
    Thats my take on building a cheap cnc
    Good luck and stay in budget! andy
    There's a lot of misinformation here. It's a bit hard to rewad, so I just scanned through it quick and will give my opinion on a few things.
    TurboCAD. Imo, not the easiest CAD package to learn. As for being a lot like AutoCAD, I think that a lot of other CAD programs are closer to AutoCAD than TurboCAD. My preference would be DesignCAD. Now owned by the same company as TurboCAD, it's cheaper, and easier to learn. But there are also a lot of free options out there as well these days.
    TurboCAD didn't write Sketchup for Google. Sketchup was around for many years before Google bought them out. http://en.wikipedia.org/wiki/SketchUp
    Don't by 24V and higher motors. Typically, the lower the voltage, the better the performance. 2V-3V motors typically work the best.
    Multiple start acme from McMaster typically has a tolerance of ±.009/ft, not .0001
    Drawer slides have tolerances far greater than .001.
    Oct 2008
    1147
    I feel differently about sketchup. It's very easy, it's free, it's fast, support is great, and there are a ton of good tutorials. I've been useing it with a free plugin to get DXF files to use with cut 2d and cambam with nothing but success. My parts come out as accurate as my machine is able to machine. I've also used it with meshcam with success. The only bad things about sketchup is doing organic shapes. I guess rendering too if you want a life like product to preview.
    On the topic of screws, I agree 1 start 1/2 10 acme should be the minimum someone should consider when buying a lead screw. It's well worth the price. However, the first thing you are going to want to upgrade once your machine is built will be the screws if you made good choices with your electronics. That's what I'm finding and will be upgrading next.
    That's all I got
    Dec 2009
    24
    CNC Under $300
    I would like to clarify a couple of points. I realize this forum is oriented towards the Pro machinist. In order to become a pro you have to start somewhere. As you know CNC almost everything in CNC is wildly expensive. Everyone does not have a $1000 to start out with. Its almost as bad as govenment contracting..mention the word government or CNC and empty your wallet and borrow on top of that!
    25 million people are unemployed or underemployed.
    If a functional (but maybe somewhat slow) machine can be built for $300 or under, then a new CNC buyer is born!!
    I did not want to get an electronics novice to wire up something that he does not understand and burn his house down. It takes technical knowldege to do the electricity/electronics..thats why I suggested higher voltage steppers..if the motor is rated at 24 volts and so is the power supply..its less of a risk for a raw beginner. You are of course right about running higher voltages on steppers.
    Most people have no idea how complicated CAD is. My point here is that instead of going freeware here..go with $25 and get a real CAD program. Yes Autocad, Rhino and Solidworks might be better, but all of those programs cost $2000. I like Design CAD also. And I also like some freeware. You usually dont get much training material with freeware. The same applys to ballscrews.. and high quality stepper controllers..Linear slides..ect of course they are better..but..the cost becomes a barrier to entry to the industry..
    If you only have $300..and its going to cost $1000 for a so called cheap machine..then there is no new CNC machinist.
    I am talking about rock bottom pricing here..how can it be done? Yes its an unsavory topic..drawer slides and $13 stepper motors and $7 ACME rod..but it can be done with some careful planning. Manufacturing technology has changed a lot..CNC is being used to make cheap stuff..there actually are drawer slides with .001 tolerances...computers can calculate the rate of decay of a router bit and adjust accordingly..same with metallurgical engineering and casting/pressing.
    I dont think there is any bad information in my post...some typo errors...I am just coming from a different direction than the pros who have to have the best gear...Maybe if someone has the time they could give the cheap low lend guys a hand and figure out what they should do.. I understand that advocating using general acme single start and drawer slides detracts from anyones credibility among the PRO user community...Maybe you could carefully word some thoughts on what is cheap and would work..just add a disclaimer of some sort so everyone knows its applicable to ulta low budget.. Any insight would be greatly appreciated.
    Maybe some of the pro users could weigh in? Or anyone one else! You might be able to create a new cnc machinist!
    Andy
    I suggested an easier to learn and cheaper alternative to TurboCAD. That's all I said.
    As for 24V steppers, I still say don't buy them. You'll have a machine that will barely move. And wiring a 3V stepper or a 24V stepper is exactly the same. They cost about the same too. Difference is, the 24V steppers won't really work very well.
    And I never said don't use acme screws or drawer slides. I just said they weren't as accurate as you said they were.
    Aug 2008
    962
    If a person has been bitten by the cnc bug and just has to have one .. I don't doubt that it can be done for $300. But it's not at all realistic to think you can build a machine that will mill aluminum at .001 tolerances for that kind of money. Even if you do manage to build one on that budget & cut some thin alum. stock very slowly, the machine isn't going to last long doing it. In your post you mention the use of aluminum and steel as being preferred. I agree, but have you priced aluminum & steel lately? Even at scrap yards it's not exactly cheap. I'm aware that Mach3 is available for free, but the trial version will only allow 500 lines of code. That's not much when you're actually trying to make something. A licensed version is $175.00. Adding the $95.00 router you recommend brings your budget to $270.00 and you've only scratched the surface and have a long, long way to go in expenditures. A machine made out of MDF, with whatever components you can find to meet budget, running freeware on a salvaged computer with anything you can find for a spindle will be a cnc indeed. You'll have fun building it and using it, and get much experience out of the process. You will also then know that you would probably have to quadruple your budget to even get close to milling aluminum at .001 consistently without beating your machine to death doing it. I don't want to quench anyone's zeal for trying something new, so I say go for it at whatever level you can! .. Everybody starts somewhere and it's a fascinating project to undertake.
    Dec 2004
    1865
    Quote Originally Posted by Andy990 View Post
    Andy
    Hi Andy,
    This site is most certainly not aimed at the Pro machinist.
    I am not a "Pro" machinist. Wish I could prove that I was so I could get a different job
    I am however a very handy person who can read and follow directions.
    I may have over 1K posts but don't assume that I am a professional machinist. While I have made money with my machine I am at best in the early stages of my journey that will never be finished.
    Most of my posts go to helping the other newbies here or I give out what I have learned in doing work or upgrades on my machines.
    As far as you have to start somewhere, I basically started here on the zone with my CNC education.
    While it would be nice for someone to build a CNC machine for $300 and be able to cut whatever they want, reality says otherwise.
    If you scrounge and look real hard you may be able to do it. It may also take three years to find all the free and inexpensive parts you need.
    $2k gets you into a ready to run Taig and it is a great running small machine that used within its limits, will teach you a lot. I also see people running several of them in small volume production environment.
    I would also say go with steppers rated for the voltage you will be running on. High voltage steppers and low voltage power supplies will just result in frustration and disappointment.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Quote Originally Posted by gd.marsh View Post
    The first two months I had my machine running, I made over $900 making parts with the Mach3 demo. I had some bills to pay with that, but set enough aside to purchase my license. now that I have a license, I can make much more complicated things and I can make even more money.
    Dec 2004
    1865
    500 lines is a lot of code.
    It came as a shock to me the first time I exceeded the limit because I had been using it for months prior to that.
    If you work within the 500 line limit for a while it also makes you write better g-code.
    I think a lot of us use cam as a crutch for many things. Myself included.
    I figure that if your cable bill is over $100 a month!, and from what I hear a lot of people pay that, $175 for Mach3 is the best bargain in the world because you will spend less time in front of the TV.
    Mike
    Dec 2009
    24
    Mass produced parts made with .00010 Precision
    Hello! As many of you know CNC has widespread use. I bought a Bottom of the line Fender Squire Affinity. It was the sample the regional manager used .. I spoke to the guy and they used a $500,000 machine to mill it. Accuracy.. .00010..
    Of course its in a mass production enviroment with a big corporation..
    But here is the point...you can buy things cheap that were mass produced with expensive equipment.
    The same principal applies to steel rod for example..There is some factory somewhere with a really nice new expensive machine cranking out standard grade steel ...( or aluminum) rod or plate thats inexpensive with .001 precision..the question is which brand (the guy who sells the $500,000 machines knows who bought em! ), who has it cheap...the same applies to other items that are mass produced..
    On items that are not mass produced..then you most likely are stuck and have to pay the going rate for a custom part...ie.. ACME nuts ect..
    Lets say you wanted a realativly cheap straight edge..buy a steel yardstick for $5..its probably .001 or better..most likely .0001
    I am doing engineering-physics and scientific apparatus protoyping so I do not really need to make parts fast, mostly complex foam molds intended to be cast metal or ceramic, and some metal parts, some wood molds.
    Anyone reading this is urged to post their thoughts and ideas on how to do cheap and accurate! Dont just read it..post a response ..what do you think?
    Quote: Mathematical and theoretical proofs are via a working machine. Its irrefutable. Patents are ok ,,but you need to prove it in a definitive manner.
    I can assure you that these guys with the $500,000 mill are not building a squire to .0001 , generally precision rod and plate would be ground and not machined ,
    suggesting watching a cnc machine remotely with the use of a webcam is an extremely dangerous thing to suggest to someone who knows nothing about the true dangers of cnc , mdf dust can flare up pretty fast and unfortunately by the time you get to your machine you may get there in enough time to watch it burn .
    as far as building economical machines I believe that most of us who had build routers have looked at most options to realistically build an economical machine and there are a lot of success stories and great ideas because of it . i think it would be to your benefit to do some searching thru the forum so that you can get some better information from people with experience ,
    i think that if your really interested in getting into cnc then you will find a wealth of knowledge here
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Dec 2009
    24
    Hello! Thank you for the heads up on MDF dust! Here is a 10 cent solution to the webcam hazard.
    Place the webcam in a used glass jar with a hole in the cap sealed with rubber gasket sealant or household caulking to spark proof it..may a gound wire on the lid too. Problem solved.
    Andy
    Dec 2009
    24
    Hello! With respect to steel rod , I was referring to getting lucky finding just ordinary stardard grade rod with good tolerances, due to advances in manufacturing technology..somebody somewhere is squeeze casting or rolling standard grade rod and plate with good tolerances.
    Andy
    sorry if you misunderstood what i meant , if a cutter gets dull or if there is a problem then the cutter will rapidly create enough heat to light a fire
    sure you can find a piece of round bar that will have a consistent diameter over the length but it doesn't mean that the next bar in the same bundle will be the same , you can probably expect that the tolerance on the material will be +or- .005" , far from being precision material
    Jun 2003
    2103
    As Gerry will vouch for me, I very seldom get in trouble here, and in fact have never really been in trouble, but I am going to have to ask some questions here that may seem a little uh..... rough....yeah rough is a good word!(nuts)
    Andy990, have you ever built a cnc machine? Ever ran one? Ever wired one? I know everyone else wanted to ask these questions, but they just gotta be answered? Have you? If so, let us see the work.
    Like some people here I run a cnc to make a living, but it is not a quality machine, and I have to fix it, threaten it, wire it, rework it so I feel as if I can speak with a little experience......and your posts do not seem to me to have any of that.
    If I am wrong, I will gladly apologize, but like Ger21 said, there is alot of misinformation in your posts.
    Where did you come up with arbitary stepper sizes based on oz/in? What is the mass that is going to be moved, what is the motion method, and how fast do you want it to get there?
    I don't like to be rude and never try to be, but I would like to make you a suggestion. Show us what you have, or sit back and begin to soak all this good stuff in that you can as fast as you can, just like we did!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Jun 2006
    106
    the web cam fire issue would be settled if I am correct by having a remote methode of fire suppression and cut off switch. then as a back up some one on premise that can be called and alerted to the issue, the final part was my idea of being able to know what is going on so I do not have to wait to have a call about something. I could anticipate issues and have solutions as soon as they are needed. I also have an interest in building a robot for maintaining things. somehting on wheels that can roll around the shop and carry out pre determined functions or be taken over remotely to do tasks that have not been prepared
    Jun 2004
    6618
    Cheap cnc builds are around. Several have been made. I doubt that many of those would mill aluminum very well though. Store bought materials generally have to have some play in them in order to reduce friction. This play is a killer of accuracy and rigidity. The more money you throw into it, the tighter and stronger it can be with proper design.
    I just paid $59 shipping included for a laser printer. Includes toner. It is effectively a cnc machine. It won't mill anything though. It does what it does by not having any cutting stresses. Often overlooked on a small budget build.
    I do use Turbocad pro, but I wouldn't recommend it unless someone has lots of time to learn it. The 2D portion isn't bad, but if you need to know the 3D and then do renderings, it escalates in the time needed to be able to use. I do like it, but it is not without it's own huge personal investment of time or learning curve.
    I have fire suppressor on my mill. It's called coolant.
    The oddest thing I have seen though is running end mills too fast and seeing them glow bright red all the while being doused in a pretty good coolant stream. Kinda defying the laws of nature a little. More akin to lava dumping into an ocean though. It is still red hot inside for quite some time afterward.
    Lot of good advice from the guys here. I too would be interested in seeing what you are talking about.
    Lee
    Quote Originally Posted by morphious69 View Post
    this would be a good method for a company but if I had my router light a fire in my hobby workshop then my fire suppression is a fire extinguisher , a water hose , and the last resort will be the soft grass that i will plant my knees into while I pray it doesn't take the house with it
    Dec 2009
    24
    Torque Multipliers-Planetary, Pulleys
    Hello! A few thoughts on torque multiplication..You can add a gearbox to increase the torque or increase the speed of the threaded rod, but its very difficult to do both..
    Some power hand tools have gear setups you can use. A lot of steeper mfgs offer gearing as an option but it costs money. A sturmey-archer bicycle transmission is fairly small and durable and able to hadle a fair amount of torque, plus you can select speed on the fly. there are other bicycle transmission hubs out there also.
    With respect to inexpensive motor sizes, cost limits what you can use. That is why 166 oz/in are suggested..this is about as big of a motor as you can find under $15..of course bigger motors are better..but..if you spend too much on one item then you are over budget. Sometimes you have to figure out how to make do with what you've got!
    This thread is about "how" do you go cheap..it requires brainpower to solve problems since you can not "buy" your way out of a bottleneck
    thank you Leeway for your insight on TurboCad and coolant and printer info.
    Thank you morphious for you insight . Thank you dertsap..any other thoughts on cheap ways of getting by?
    Attached Thumbnails Attached Thumbnails sturmey archer bike hub.jpg   torqueMultiplierWrench.jpg
Page 1 of 2 12
  1. First build, need some input.
    By RP Designs in forum Vertical Mill, Lathe Project Log
    Last Post: 04-25-2009, 09:31 PM
  2. Decent DIY AVR Programmer
    By epineh in forum CNC Machine Related Electronics
    Last Post: 05-06-2008, 06:27 AM
  3. tolerances
    By jprobst in forum Haas Mills
    Last Post: 04-18-2007, 05:15 PM
  4. ok share the knowledge share the wealth...huh...right
    By oaktree444 in forum MetalWork Discussion
    Last Post: 10-18-2005, 10:54 PM
