587,997 active members*
2,448 visitors online*
Thread: motion?
    46
    motion?
    hi,
    I am completely beginner in the field and I ve just received my driving board and steppers from stepperworld and I am starting to build the frame for the router...
    I ve one question still without answer...
    how the program or board will know that one rotation of motor = X mm of displacement ot my X, Y or Z axis???
    is there any setup to be done at some stage to make the correspondance between rotations of the motor and motion of gantry?
    thanks in advance for your clarifications...
    Jun 2004
    450
    All of those settings are done in the software that you choose to control your machine.
    46
    ok
    ok thanks!
    Nov 2003
    634
    That's correct, those settings are in MACH2 or TURBOCNC. You have to create them and enter the numbers into the programs. The board doesn't know or care about the distance. It simply controls the steps.
    Note: Each program sets up the rotation/movement differently. TURBOCNC was way easier to understand than MACH2. But once its done, you don't have to worry about it anymore.
  1. Linear Motion FAQ
    By Cutters Cove in forum DIY CNC Router Table Machines
    Last Post: 03-08-2018, 02:14 AM
  2. Series 2 BOSS 6 Axis motion problem
    By craig96us in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2006, 06:06 PM
  3. TurboCNC with PC Motion Card??
    By Al_The_Man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-06-2005, 10:41 PM
  4. Kerk Motion Leadscrew Possible Problem
    By ThomasAlva in forum Mechanical Calculations/Engineering Design
    Last Post: 01-27-2005, 07:17 PM
  5. MaxNC motion kit for Sieg X3 mill?
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-16-2004, 06:24 AM
