586,100 active members*
2,749 visitors online*
    Dec 2009
    23
    Torque Mode vs Velocity
    My amps support both velocity and torque modes. Is either method perfered?
    Do I need to tell the control which is being used, if so, how do I do this?
    Jeremy
    Mar 2004
    1543
    I've done five machines to Camsoft now and always used Torque mode. All Galil (Camsoft) knows about the drive is the correct P I D settings. You really have to read the drive's manual for more set up info.
    From what <little> I know, velocity mode is often used on servo spindles.
    Karl
    May 2007
    781
    Most of the velocity mode servo systems I have seen were on machines that needed to move very slow and smooth. Mostly wire and sinker EDMs.
    Edit:
    Newer all digital systems get the smooth motion by using encoders with very high count resolutions. Either way good analog tach or high resolution encoder is expensive.
    24221
    I have always used mine in the torque mode, Galil also recommend this.
    Al.
    Albert E.
    Dec 2009
    23
    Thats good to hear, torque mode seamed to be the simplest solution.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. VSD-E: What is the full torque range in STEP/DIR mode?
    By LBodnar in forum CNC Machine Related Electronics
    Last Post: 07-15-2009, 08:22 PM
  3. AMC BE25A20 drive in encoder velocity mode.
    By lucas in forum Servo Motors / Drives
    Last Post: 04-02-2009, 06:58 PM
  4. Constant Velocity Mode CONSTANTLY DIES!
    By backlashphoenix in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2007, 12:52 PM
  5. Replies: 2
    Last Post: 04-19-2007, 03:37 AM
