588,211 active members*
4,326 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > GRIZZLY G0602 10x22 LATHE UNCRATE & TEARDOWN
Results 1 to 14 of 14
    Mar 2008
    3655
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Oct 2007
    Post Lucky Guy
    Looks like you are a lucky guy in that the crate was not damaged. I receieved by 10x22 lathe back in June 2009 and the lathe was sitting on another pallet as the factory pallet was broken and the crate was also damaged. Found a little scratched areas of paint, nothing touch up paint would not take care of. I too was a lucky guy, after readings some of the posts before I received the lathe about how some the lathes had broken emergency switch and off and on switch.
    Oct 2008
    1645
    CR, hurry up and CNC that thing !! We're all waiting !!
    Mar 2008
    3655
    Hi RW!
    All in due time. So much to post, and so little time.
    CR.
    Mar 2008
    3655
    Quote Originally Posted by thinking man View Post
    Wow TM. You've got to get out more.
    Yep, we're BOTH lucky guys. Anybody who has this wonderful lathe is a lucky guy!
    CR.
    Oct 2009
    483
    CR,
    What a great photo essay of cleaning and dismantling a Grizzly G0602 10x22 lathe. You've made my teardown of my new lathe much less stressful.
    Now that I've got the carriage and cross slide and compound all in pieces, what is the next step? I'm unsure of what to use to relubricate the cross slide and compound screws. Lithium grease? Way oil?
    Also, should I be squirting way oil into the ball oilers instead of 10 weight like the Grizzly manual suggests? From another post you made, I'm avoiding oiling the two ball oilers on the spindle bearings so that the bearing grease is not washed away.
    Mar 2008
    3655
    Quote Originally Posted by Titaniumboy View Post
    CR,
    Thanks TB!
    I will be using flood cooling with Synkool, so don't want any organic tramp oil to get into the coolant sump. Because of this, I use Mobile One synthetic 10W-30 for way oil AND ball oilers.
    I don't use the gearcase--it's still full of the oil it came with. My threading will be done by CNC.
    CR.
    CR.
    Oct 2009
    483
    CR,
    Thanks for the reply.
    So if you're using Mobil 1 in the ball oilers, I guess that will lubricate both the ways and the cross slide screw?
    I noticed that the cross slide has ball oilers, but the compound does not. Kind of strange. I imagine that you won't be using the compound once your CNC conversion is finished?
    I removed the faceplate in order to get a lock at the spindle bearings (and also to remove those last pesky pieces of plastic wrap that was protecting the faceplate). I suppose there might have once been grease in the bearings, but I sure don't see any grease there now. The whole design of the spindle bearings having being open, and then having ball oilers just dribble oil on the outside of the spindle bearings is just poor. I think I'm going to try and smear some grease on the side of the spindle bearings and hope some of it ends up being in a place where it can do some good.
    Jan 2009
    402
    Congrats
    some day .... I hope to get the same lathe...
    clicking my heals three times
    Sep 2006
    1738
    Posting for future use.
    -Jason
    Nov 2007
    980
    Quote Originally Posted by SpeedsCustom View Post
    -Jason
    Jason, rather than posting an old thread, you can just use the "subscribe" option in the "thread tools" menu shown in the picture below.
    Dave
    Dave->..
    Sep 2006
    1738
    I should no better!
    (chair)
    Feb 2010
    60
    My chuck is stuck on, but those spanner nuts turn off the spindle when I grip them with the pipe wrench.
    Feb 2010
    60
    so I had to take the pully off and use a pipe wrench on the spindle, with a towel around the spindle.
  1. Grizzly G0602 10" x 22" Lathe Conversion
    By derekbackus in forum Vertical Mill, Lathe Project Log
    Last Post: 01-29-2019, 09:29 PM
  2. New Grizzly G0602 10x20 Lathe
    By twehr in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2013, 05:15 AM
  3. Grizzly G0602 10x22 Lathe Conversion
    By Steelpolish in forum Vertical Mill, Lathe Project Log
    Last Post: 01-21-2011, 11:04 AM
  4. Grizzly 10x22 lathe, and X3 CNC conversion build log
    By TacPyro in forum Benchtop Machines
    Last Post: 05-06-2009, 06:30 AM
  5. New G0602 10x22 cuts a taper
    By rwskinner in forum Mini Lathe
    Last Post: 10-31-2008, 11:34 PM
