588,489 active members*
3,969 visitors online*
    Jan 2004
    39
    Unhappy Tool holder trouble
    Hello everyone I have a converted manual mill,
    and I am considering building a toolchanger for it.
    The trouble I have is that the tool holders are sticking inside of the taper.
    Usually I am forced to screw the drawbar back in a bit and hit on the top of it until it lets go of the taper so I can remove it.
    is there anyone that have had similiar trouble to this, and that has a solution?
    Jun 2003
    1365
    What kind of tooling is it and what kind of drawbar do you have? with mine, I am building a power drawbar and it will keep pressure down on the drawbar as it unscrews and that will be enough to pop mine free.
    It is probably similar with the larger machines too.
    Jon
    Jun 2004
    450
    JFettig, something like this? http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
    Looks simple enough to build.
    Aug 2004
    2849
    Look at the Tormach for ideas for an inexpensive solution. Most of the tapers for manual machines are as you describe.
    I you want to use the CNC tapers used on larger systems....then it will most likely be quite costly....but the tooling will be readily available.
    Jun 2003
    1365
    Dab, mine is similar, but I just press a button on the side of the head and I have an air cylinder to push it down onto the drawbar and loosen or tighten.
    Its search "power drawbar" on google, there is a guy selling plans which I bought and heavily modified the design
    Jon
  1. Tool length sensing!
    By Swede in forum FlashCut CNC
    Last Post: 05-07-2013, 04:38 AM
  2. Bostomatic tool holder specifications
    By Kmed in forum Uncategorised MetalWorking Machines
    Last Post: 01-22-2010, 09:56 PM
  3. Help needed identifying Tool holder and Collets
    By gtslabs in forum Uncategorised MetalWorking Machines
    Last Post: 03-20-2005, 08:25 PM
  4. Tool Changer Problems
    By Snel in forum Haas Mills
    Last Post: 08-11-2004, 02:56 PM
  5. tool holder
    By corrie in forum DIY CNC Router Table Machines
    Last Post: 07-23-2004, 10:04 PM
