586,438 active members*
4,269 visitors online*
Thread: edgefinder
Results 1 to 7 of 7
    Dec 2008
    39
    edgefinder
    i am looking for an electronic edgefinder that will work any material
    i cut wood & plastic
    any ideas?
    thx
    mike
    Feb 2006
    992
    Check MSC catalog, normally Electric edgefinder work with metal ...... 'cause it need ground to trip the light. But I think they also have electric edgefinder with a spring load and claim work with any material but it's expensive you are talking $200 plus.
    The best way to learn is trial error.
    Dec 2008
    39
    i checked they said they didn't have one
    any more ideas?
    thx
    mike
    15362
    Hi basswakr
    There is a laser that you can use I don't have the spec but they are in the home machinist magazine
    Found it http://www.lasercenteredgefinder.com/
    Mactec54
    May 2005
    2502
    Those kind of lasers are just visual, and not so accurate as a regular edgefinder.
    I'd go with a 3D probe. The actually require the motion to move the tip to register the edge, so will work with materials that don't conduct electricity.
    I got one like the one in this thread:
    http://www.machsupport.com/forum/ind...ic,5004.0.html
    Haven't had a chance to play with it yet, but it was very well made for the price.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jan 2010
    34
    What's the issue with a standard edge finder ? If used correctly it will get you real close. If you need it closer you can always sweep edge with an indicator. Takes more time but very accurate.
    Dec 2008
    39
    there is no issue with reg. edgefinder
    the electronic will be much faster & easier.
    i ordered the probe that bob suggested &
    will let u know how it works .
    thx for all your help guys
    mike
  1. electronic edgefinder
    By basswakr in forum CNC Machining Centers
    Last Post: 01-12-2010, 06:16 PM
  2. Electronic edgefinder
    By Hack in forum MetalWork Discussion
    Last Post: 11-23-2009, 04:53 AM
  3. Aligning workpart with edgefinder similar to Mach3 possible?
    By germaza in forum LinuxCNC (formerly EMC2)
    Last Post: 10-16-2009, 07:04 PM
  4. edgefinder
    By krymis in forum Charter Oak Automation Support Forum
    Last Post: 01-02-2007, 05:40 PM
