586,110 active members*
3,354 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Dont know where to start... Mill Electronic PCBs
Results 1 to 8 of 8
    Mar 2005
    269
    hi guys, im from argentina, i want to made 2 machines one for router wood and another to create holes in electronic PCBs......
    for woodworking ill create something like JGro CNC Router. this looks nice for me....
    but dont know in wich forum i can read info abt the PCBs,... i dont need to create something to route.
    Can someone tellme where to start?
    Thanks..
    Feb 2005
    Talking pcb
    Hola,espero que te sea util.
    busca en el foro al mas ducho en el tema de pcb,su nick es
    PMinMO. Su pototipos son de libre uso,no comercial solo personal uso.
    el ultimo proyecto en el que trabaja esta pidiendo unas donaciones o piensa vender el pcb a un precio economico para sufragar gasto.
    suerte.
    Mar 2005
    269
    thanks aalberto09, but im looking for an prototype or some doc abt cnc machines to drill PCBs, i found nice stuff abt woodworking machines, but dont know if will be useful to drill PCBs too.
    dont know in wich section of the forum read abt machines to drill the holes in the PCB.
    49
    PCB Mill
    We use a LPKF PCB Mill. It is just a small CNC mill. I have been thinking of using a regular CNC mill to do PCB's. The LPKF uses standard end mills and drill bits.
    Your question is how do I go from my circuit board design to G code for my mill?
    I can help there a little.
    As far as the mill it should be very simple to make PCB's.
    Give me more a reply so we can get to what exactly you need.
    Mar 2005
    269
    thanks sundy.... so if i made an design for example with proteus i need to convert it to "G Code" and later mill?
    i can use any soft to create the PCBs and later is easy to convert it to G Code?
    49
    PCB Mill
    It looks like Proteus outputs standard CAD/CAM formats. Then you need a post processor to convert to what your mill uses.
    I hope someone else will wade in here if I'm wrong.
    How do you go from CAD to your mill now? The same software should work.
    Mar 2005
    269
    i dont have any soft
    49
    PCB Mill
    A lot of people here use bobcam. I haven't used it so can't tell you much. I think you should go to the http://www.cnczone.com/forums/forumdisplay.php?f=250 General Control forum. Perhaps look at LPKF website http://www.lpkf.com/index.htm. Good luck!
  1. Tools advice needed for start
    By pigifly in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2009, 10:18 PM
  2. wich Machine can i buid to mill PCBs?
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 05-23-2005, 10:23 PM
  3. Any options for an old mill?
    By bjorn in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-04-2005, 05:55 PM
  4. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
  5. 2D Toolpath Start Point?
    By mlinder in forum OneCNC
    Last Post: 09-07-2003, 05:28 PM
